brake problem
Old Dec 28, 2003 | 07:11 AM
Sam268's Avatar
Default brake problem
my front brakes are sqeeking like crazy when I stop at low speed.. noting on the highway.. is when I almost come to a complete stop like start from 10km and under.. it will squeek unitl I make a complete stop. I just check my brakes and lube the caliper pins.. there is still meat on both sides of the pads and the rotor looks fine.. does not vibrate when I step on the brake so the rotor is not warp...
how come is making a noise at low speed breaking???
Old Dec 28, 2003 | 07:22 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: brake problem (Sam268)
Get some Brake Clean?
Old Dec 28, 2003 | 07:26 AM
Sam268's Avatar
i spray the rotor with brake cleaner as well while the pads were off. i really don't know why it only squeeks at low stopping speed. and is really loud too..
say I step on the brakes at 50 and all the way to a complete stop.. it would only start to squeek when I am down from 15-0 km..
Old Dec 28, 2003 | 09:12 AM
TeamNextGenChris's Avatar
you need to remove the pads and put some anti-squel compound on the backside of the pads.this is most likely the problem.you can get a one-time use pack of it at any auto parts store for a couple bucks.
chris
Old Dec 28, 2003 | 09:15 AM
B18C2_sedan's Avatar
Default Re: brake problem (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">you need to remove the pads and put some anti-squel compound on the backside of the pads.this is most likely the problem.you can get a one-time use pack of it at any auto parts store for a couple bucks.
chris</TD></TR></TABLE>
right on. That will fix it
Poopie
Jun 25, 2004 07:03 PM
yaya
May 19, 2003 08:18 PM
garados
Oct 15, 2002 03:39 PM
integra0260
Oct 21, 2001 08:09 AM
RH+G
Jun 26, 2001 01:34 PM
