heater warmth
Make sure the valve is opening. You will find a cable going to it from the control unit thru the firewall. It is on the passenger side below the fuel filter.
For those who are having trouble with the speed settings-check that the resistor is OK. You might find one online, otherwise the dealer has them available.
well i have a deal core radiator and the temp gauge in the cluster console like never rises it stays rock bottom but sometimes it moves up but thats like in the day when its warmer at night it stays rock bottom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">Does the engine reach normal operating temperature fairly quick? If not, might be time for a new thermostat. I would replace it with an OEM stat.</TD></TR></TABLE>
did you recently change your coolant?
It could be a bad thermostat, or it could be that the new coolant is cooling the car better and _if_ its that cold in your area, it would explain why it cant reach operating temperature....it SHOULD reach it while idling for a while tho after a drive
884door
Apr 23, 2006 08:04 PM
nucrxowner
Jan 18, 2005 12:52 PM
