check engine light
Old Dec 27, 2003 | 04:14 PM
Scott_Taylor's Avatar
Default check engine light
I have a 02 civic si and installed the magnaflow cat back and a high flow cat that is currently availible on ebay. Drove the car around for about 20 minutes and the check engine light came on. I also noticed that it smelled pretty hot too. What is the deal?? Any help will be greatly appreciated.
Thanks
Old Dec 27, 2003 | 11:54 PM
RsxVengeance's Avatar
reset your ECU and see what happens.
Old Dec 28, 2003 | 09:12 AM
Jim Truett's Avatar
Default Re: check engine light (Scott_Taylor)
Last high-flow cat off of eBay for the EP I saw was really a test pipe. Basically the unit is not a catalytic converter at all. I assume if you scan the PCM for trouble codes, you will probably get a code #P0420 "catalyst efficiency below threshold". The "hot" smell is typical of new exhaust components, and it will go away in a couple of days.
Old Dec 28, 2003 | 10:59 AM
Default Re: check engine light (Jim Truett)
Well I took it of and put the stock one back on and reset the ecu. And so far the light has not come back on. But is there a high flow cat for this car out there? Also I have the DC Sports header on the way This isn't going to give me the same problem is it?
Thanks
Old Dec 29, 2003 | 06:44 PM
Jim Truett's Avatar
Your DC header will not cause problems. The only true high flow cat for the EP right now would be a fabricated unit from a reputable exhaust shop. There are no good off-the-shelf units right now.
Old Dec 30, 2003 | 04:18 AM
Thanks man thats what I needed to know.
superchargedex
Apr 28, 2005 04:54 PM
fastitr01
Jun 6, 2004 06:17 AM
fastitr01
May 28, 2004 07:56 PM
Nelo_VTI 1.5 JDM
Dec 4, 2002 02:22 PM
GSRacer1
Nov 15, 2002 12:38 PM
