timing belt problem HELP ASAP PLZ!
honda accord v6 1995.
I took the timing belt off and for some reason my rear cam sprocket is 5 teeth past the mark. The front cam sprocket and my crank sprocket is lined up through perfectly. How do I turn the cam sprocket back? It is so hard to turn. SHould I turn it back to the mark or foward to the mark? I don't want to damage my valves.
Well there are seal puller u can get them from snap on or matco even craftsman but u have to becarefull when installing the seal not to roll them over or you will have to redo the job all over again cuz it will spew oil all over everything.
wk9k
Mar 13, 2012 05:45 PM
Civicman86
Jun 22, 2006 10:01 AM
