Replaced Distributor, still getting check engine light # 9 No 1 Cylinder postition sensor
Old Dec 26, 2003 | 09:44 PM
USDM91crxSi's Avatar
Default Replaced Distributor, still getting check engine light # 9 No 1 Cylinder postition sensor
Got a new (rebuilt distributor) reset the ECU, tried to time the ignition, made sure cam timing is ok,
still getting the ECU code 9
I'm lost
Old Dec 30, 2003 | 10:18 AM
ZC1.8crx's Avatar
Default Re: Replaced Distributor, still getting check engine light # 9 No 1 Cylinder postition sensor (USDM9
need more info but had they exact problem in my 88si with a zc motor you have to go thru your timing. put it in tdc align the cam gears, and then try to set intial timing.
Old Dec 30, 2003 | 01:41 PM
phatrick2332's Avatar
im assuming this is in an Si ?
Old Dec 30, 2003 | 02:04 PM
[626]95-GSR's Avatar
ive got the same problem.. and im still stumped. Ive replaced my distributor a few times. ive heard it is the wiring.
Old Dec 30, 2003 | 02:07 PM
i had this problem with my car also, but im swapped to mpfi. The problem was in wiring, i tore it all apart and redid it, and the codes gone now.
Old Dec 31, 2003 | 07:34 AM
Eresuncabron's Avatar
Default Re: (phatrick2332)
i'm gettin the same code now.
should i get a new distributer or should i re check the wiring
Old Dec 31, 2003 | 07:37 AM
blackwagon's Avatar
Default Re: (Eresuncabron)
just swap and repin the two wires for the sensor
i dont remember the colors off the top of my head
but do a search and swap them should go away
Old Dec 31, 2003 | 08:03 AM
Default Re: (blackwagon)
does nebody have a good wiring diagram of the ignition system of a 91 crx si??? plz help
my service and repair manual sux
Old Dec 31, 2003 | 08:11 AM
the wires go like this
c1(orange) to blue/green
c2(white) to blue/yellow
And you can check fourthgenhatch.com for all the wire colors theres a post at the top of this forum today.
Old Dec 31, 2003 | 08:55 AM
biggdogg's Avatar
also check b10 and b12 . tdc sensor
Old Dec 31, 2003 | 09:25 AM
MonkeyMagic's Avatar
previous owner wired my zc swap, now im rewiring the entire car one wire at a time
Old Dec 31, 2003 | 10:03 AM
DJ_SaNdOz's Avatar
Default Re: (lilredej2)
swap the two wires that go teh Cam sensor, or sauter (sp) them if they are just twisted together. In most cases that code is due to crappy wiring or having the wires reversed. G/L
Old Dec 31, 2003 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackwagon &raquo;</TD></TR><TR><TD CLASS="quote">just swap and repin the two wires for the sensor
but do a search and swap them should go away</TD></TR></TABLE>
what wires
where?
d16a6 engine?
Old Jan 1, 2004 | 06:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">the wires go like this
And you can check fourthgenhatch.com for all the wire colors theres a post at the top of this forum today.</TD></TR></TABLE>
these wires
they run from the distributor to the ecu..check them, wire them, enjoy.
Old May 5, 2004 | 11:24 AM
CRneXt's Avatar
So, if one cam shaft is out of synch, this can happen???
I am getting this code, and am not quite sure why.
I have a 1992 B18A with a MSD cap, and a Blaster2. I had a #8 and #9
After reset, I am still getting a code #9
thanks for the help.
Scott
Old May 5, 2004 | 12:09 PM
USDM 4G VTEC's Avatar
i have wired about 10 MPFI and they are sucesfull
on my car (ironic isnt) i cant get it right
thats the only code i have
i have done all in my power to get it away
-taken a new ecu in
-new distribuitor
-rewired it 4 times and still there
-switched the cables
-re-run cables with a shielded one and separate
and havent had iti working
i gave up since there seems to be not a solution, no power loss (dyno proven) and runs great... so i say **** it
Old Sep 14, 2004 | 09:16 PM
4potnick's Avatar
I have the same problem on a 88hf with dohc zc. I've put on new sensor and dizzy and still have the problem. Even re-ran the wires to cps to ecu. nothing.
Can you put sotch hf dizzy on dohc zc. I want nothing to do with external sensor.
Old Sep 15, 2004 | 01:09 AM
Waachback's Avatar
I just raised my idle a little, did my timing and it went away.
Old Sep 17, 2004 | 06:06 AM
4potnick's Avatar
Anyone had this problem on a dohc zc? I know it is not the sensor or the wiring going to the sensor?
Old Sep 17, 2004 | 07:52 AM
crx_88_si's Avatar
u sure its not the sensor on the exhaust cam?
EDIT: code #9 on a DOHC ZC is the sensor located on the exhaust cam.
B16Blake
Nov 30, 2009 09:18 PM
ecstacyofgold
Apr 12, 2009 06:42 AM
Brandoff
Nov 19, 2008 04:29 AM
civicsi_5289
Aug 25, 2008 09:36 PM
crackercr-x
Aug 4, 2004 05:57 AM
