idle rpm question
Old Dec 26, 2003 | 08:39 PM
kool168's Avatar
Default idle rpm question
i have a jdm itr motor and it idle at 1000 rpm, and i asked people and they said normal is at 800 rpm...
obviously the motor has higher rpm than normal during idle
i tried to plug in the p30 ECU (B16A2), and it idle at 800 rpm. when i plug back my p73 ECU, then it idle at 1000 rpm
anyone have idea wut is going on? and how to solve the problem? or it is just normal and nothing to worry about?
thankz for reading this
Old Dec 26, 2003 | 08:48 PM
Erik_Pb_Foot's Avatar
New User
Default Re: idle rpm question (kool168)
have you tried adjusting the idle screw? its a slotted screw on your tb that is about flush with the surface... near the opening... dont remember exactly but you can't miss it....
Old Dec 26, 2003 | 08:54 PM
HYREV2NR's Avatar
Default Re: idle rpm question (Erik_Pb_Foot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik_Pb_Foot &raquo;</TD></TR><TR><TD CLASS="quote">have you tried adjusting the idle screw? its a slotted screw on your tb that is about flush with the surface... near the opening... dont remember exactly but you can't miss it....</TD></TR></TABLE>DITTO!!!
Old Dec 26, 2003 | 09:05 PM
sgT's Avatar
sgT
check ignition timing as well
Old Dec 26, 2003 | 11:35 PM
kool168's Avatar
oh i might try that tomorrow
but why when i plug the p30 ECU and it goes back to 800 rmp?
will this higher idle rpm problem do damage on engine? if it doesn't affect the performance or do damage on engine, i might just leave it
Old Dec 27, 2003 | 07:47 AM
New User
it's not going to mess anything up but it shouldn't be idling that high. the idle adjustment screw is there to correct idle problems. just use it. honda designed these motors to idle at certain rpm's for a reason, probably gas consumption but none the lessjust try adjusting it. is your cel on?
Old Dec 27, 2003 | 08:04 AM
richone009's Avatar
I have the same problem, good idea
maverickiz3d
19
Oct 16, 2015 03:17 PM
ciiivic89
Feb 9, 2009 07:03 PM
drowzysleeper
May 18, 2005 01:40 PM
jerbear!
May 9, 2005 11:00 AM
quik2kSi
Dec 27, 2003 09:04 AM
