ef heat
Old Dec 26, 2003 | 01:12 PM
misledyouth_is_back's Avatar
Default ef heat
i was wondering how hot your heat blows.
when i touch the heater core it doesn't seem hot. The side door that redirects the air to the heater core leaks and lets cold air in. So it blows cold from one side.
just curious how hot your heat actually blows.
jesse
busychild's Avatar
Default Re: ef heat (misledyouth_is_back)
I can burn the skin off your ankles if I leave it on high
Old Dec 26, 2003 | 01:43 PM
kid-honda's Avatar
All of mine are to hot on setting 2.
Old Dec 26, 2003 | 01:47 PM
Tyson's Avatar
if your heat isnt almost hot to the touch on MAX, then you should adjust/fix the air mix flap cable. its NOT the same as the coolant mix valve, theres another cable that is simultaneously adjusted when the **** is turned. crawl underneath the dash from the passenger footwell and look straight up from the center console, you should see the cable going to a white lever. you should be able to reach the adjustment **** and see if its working within the full range. this is the most common heater related problem.
Old Dec 26, 2003 | 02:03 PM
Default Re: ef heat (Tyson)
yeah that is working fully that is what we checked.
i am thinking that maybe my heater core is clogged but i am not sure.
jesse
Old Dec 26, 2003 | 04:14 PM
bossman032's Avatar
soo that means u can adjust how hot the heater air you want?
Old Dec 26, 2003 | 04:52 PM
FourthGenHatch's Avatar
Default Re: ef heat
Is that why everyone says their heater never works on the first setting? Because they came out of adjustment? I will have to try that some time.
Old Dec 26, 2003 | 05:02 PM
Riceburner247's Avatar
Default Re: ef heat (FourthGenHatch)
Mine throws out flames. It hurts to hold your hand on the vent for more than 15 seconds.
Old Dec 26, 2003 | 05:09 PM
Tyson's Avatar
Default Re: ef heat (bossman032)
just to resolve any confusion, the adjustment **** that controls hot air mix is the same as the "temp" ****, not the blower speed (1-2-3-4).
Old Dec 26, 2003 | 07:57 PM
Cory man's Avatar
If your heat isnt as hot as it "should" be it may be time to flush the cooling system. Ive had a few cars that had cooler air when the heat was cranked. I flushed the cooling system and now you can cook eggs on the dash.
Old Dec 26, 2003 | 09:40 PM
Default Re: ef heat (Cory man)
i think this is my problem i am gonna try and take it in next week. So we'll see what happens.
jesse
pxsx
16
Nov 11, 2012 11:24 PM
Evolution-93-Ex
Jul 31, 2009 03:25 PM
honda4674
Jan 20, 2006 06:53 AM
TheIceMan
Feb 20, 2005 02:20 PM
GRAVEDIGGER
Nov 16, 2002 01:25 PM
