B20 BUILD QUESTIONS
Old Dec 26, 2003 | 01:54 AM
NiceITR
Guest
Posts: n/a
Default B20 BUILD QUESTIONS
Hello everyone:
I currently have my ITR in the shop (blew a hole in the block). I came across a 98 hatch back from a friend. I figured it would be a great project to put a B20 in it. I have been looking at DART blocks for a b20.
My questions are:
Has anyone built one of these b20 blocks for bigger displacement? If so, how big did you go?
How is the redline on it? Can it rev to 8500rpm if the displacement is around 2.2 ~ 2.3L??
I am most likely going to do a 84mmx95mm bore/stroke.
What kind of Compression can be run on a bigger displacement block if the block is sleeved?
Help is always appreciated.
thanks,
Old Dec 31, 2003 | 08:54 PM
BluePrintmfg.com's Avatar
Banned
Default Re: B20 BUILD QUESTIONS (Manuel)
B20 stock sleeves 84.5 High comp. pistons
89 mm crank
B16 head welded chamers ported and polished
ITR manifold
Jun III cams
226@whp back in 2002 daily driven
Old Jan 1, 2004 | 08:57 PM
NiceITR
Guest
Posts: n/a
Default Re: B20 BUILD QUESTIONS (11sec.ALL MOTOR)
Thanks for everyone's input. I was looking at the DART blocks. They have a b20 block already decked but instead of 84mm bore they also have a standard 81.25mm bore. I was thinking about picking one of these blocks up because I have CTR pistons just sitting here collecting dust.
Do you think the compresson ratio will be too high then?
Thoughts??
Comments??
Thanks
blackeg
Aug 9, 2008 03:06 PM
Suprdave
23
Mar 23, 2005 05:12 AM
NCHATCH
Acura TL, RL & ZDX
Mar 4, 2003 08:50 AM
CTRwannaB
Jun 4, 2002 11:40 PM
TypeR0149
Aug 22, 2001 12:32 AM
