Estimated time for 2001 ITR
Old Dec 25, 2003 | 09:41 PM
Driver's Avatar
Default Estimated time for 2001 ITR
What would a 2001 ITR with good (DOT) tires and some advance ignition timming could run in the 1/4 mile with no weight taking out except for the spare&jack.
Ps: The car as NO a/c and would run at see level with a very good driver.
What do you say ??
Old Dec 25, 2003 | 09:50 PM
Ass_Clown's Avatar
Default Re: Estimated time for 2001 ITR (Driver)
14.7-15.0
Old Dec 25, 2003 | 10:29 PM
JjuuN R's Avatar
14.4-14.7 probably if you run without the PS belt/no ac
Old Dec 25, 2003 | 10:32 PM
Drag_Racer_DRU's Avatar
Default Re: (JUN.R)
doesnt the onwers mannuel have that information haha
Old Dec 26, 2003 | 09:09 AM
Austin's Avatar
Default Re: (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">14.4-14.7 probably if you run without the PS belt/no ac</TD></TR></TABLE>
14.3 is possible with some semi-sticky tires and no PS belt.
Austin
Old Dec 26, 2003 | 09:42 AM
TurboLSVtecTeg's Avatar
Default Re: (Austin)
I do know its possible to get low 14's outta a stock R. My friend had us advance his timing 2 degrees. No other mods, no weight reduction and one of my friends who can drive his *** off hit a 14.2 @ 98mph. So I know it can be done but it really depends on the driver.
Old Dec 27, 2003 | 03:23 PM
Driver's Avatar
Default Re: (TurboLSVtecTeg)
Well i'm glad you guys gave quite decent times. For some reason, people who don't know much about the ITR's potential to be quick (even in a drag race) and NOT only on a road course or a solo pad. The 2001 ITR's with no A/C seems to be fast for some reason when compared to other years of production. I was asking for times you tought possible given a strong car with a strong driver on a perfect day and with the ONLY mods being some advance on the ignition timming and the P/S belt removed and also I removed the external air box resonator (the one in the fender). NO weight had been taking out other than the spare tire and jack. An other factor to specify is that these times i'll be posting were done on 2 different lanes at an NHRA approuved race track tha is 170 ft above see level. The weather was around 70 degrees with no wind an 70% humidity.
The driver (myself) weighs 185 lbs !
The ITR with those simple FREE mods dynoed at 170.4 whp with 119.4 wtq !
Here are the times: 3 runs total.
first run : 14.27 @ 98.5 mph
second : 13.97 @ 99.2 mph
third run:13.98 @ 98.7 mph
The reason for this post is not to brag or **** on anyone, mostly because I find it important for all ITR fanatics out there to beleive there is hope to be quick in a strait line with a car desinged to go fast around corners.
Old Dec 28, 2003 | 06:32 AM
Default Re: (Driver)
What kind of tires was that done one and could you give a more detailed time sllip i.e. 60 ft, 1/8 mph/et.
Old Dec 28, 2003 | 08:05 AM
Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">What kind of tires was that done one and could you give a more detailed time sllip i.e. 60 ft, 1/8 mph/et.</TD></TR></TABLE>
60FT: 2.17
1/8 : 8.990
1/4 : 13.970 @ 99.225 mph
60FT: 2.19
1/8 : 8.995
1/4 : 13.985 @ 98.762 mph
The tires were Toyo RA1 205/50-15 (DOT) solo/circuit tire with a stiff sidwall. Not the best kind for Drag racing but I had droped them to 15 psi.
The 14.27 run, I can't find the slip but I remember the 60FT to be quite high 2.30-35 ! The track was dirty since it was at the beginning of the day. I spun all of first gear and about 10 ft in second gear.
I launched at 7000 rpm with little feathering of the clutch if needed.
Old Dec 28, 2003 | 11:33 AM
Very good times. Keep up the good work man.
Old Dec 29, 2003 | 05:42 AM
95VXB16A's Avatar
From what I've seen they run anywhere from 15.3 to 15.1 pretty much stock, with a moderate driver. Once U get I,H,E=14.9 to 14.5 with a good launch.
Old Dec 29, 2003 | 06:12 AM
b19coupe's Avatar
Very nice times-wish I could drive that well
Old Dec 29, 2003 | 05:55 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Sounds right to me.
Old Dec 29, 2003 | 08:39 PM
hybridEj6's Avatar
Default Re: Estimated time for 2001 ITR (ActiveAero)
ive seen a jdm 98 spec r he 14.27 with the drift king behind the wheel
Old Dec 30, 2003 | 01:17 PM
Fac3Man's Avatar
Default Re: (95VXB16A)
15.1 15.3's? Must be horrible driving I guess.
My 01 R with a filter ran 14.7@96mph on bald RE010, I'm a pretty shitty driver too. It's possible to squeeze a 14.2 out of my car with a decent driver.
hutcho3
Apr 8, 2011 09:00 AM
95bkeg
Jul 5, 2006 07:51 AM
EnjoyTheRideDC2
Nov 23, 2005 08:07 PM
Tampa94lsteg
Apr 26, 2005 10:08 PM
001020
10
Feb 16, 2004 08:30 AM
