Stock LS block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ophdehEEzY »</TD></TR><TR><TD CLASS="quote">How high can a bone stock LS block rev? </TD></TR></TABLE> To it's stock rev limiter....I believe is like 6800rpm or so. Even if your head is built, I wouldn't take it much higher than that.
safely..assuming everyday i wouldnt go more than 7k. shotpeen the rods, arp rod bolts, block girdle and balance your bottm end then you'd have no prob going up to 8-9k. if you want to rev to 8-9k easy get a VTEC block
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid02 »</TD></TR><TR><TD CLASS="quote">I take my stock B20z bottom end to 8000 RPM and it sees 7500 a lot.</TD></TR></TABLE>
I wonder if that's healthy
stock block stay with stock reline like 6,800
arp rod bolts shoot peened ls rods, ls rods renotched for gsr rod bearings, blance whole roating assemble, and your good for 8k+
Modified by riceball777 at 9:46 PM 12/26/2003
From: First in Flight, Type Rs of East Coast, NC, FL
Well we had an ls with bullfrog computer (stock block, bottom end, head, cams), we turned this car on the street and dragstrip 8100 rpm everyday more than once a day since mid 1997 till early this year when it finally blew up. Stock rods finally let go, cylinder number 4 rod failure, snapped the rod in half, then smashed the rod cap into two pieces and sandwiched the two pieces against the bottom of the sleeve and the rod journal, and well that was the end of that rotating assembly. Block was usable after boring. Suprised that after all that beating we gave it it actually lasted that long, had pictures of the rod and cap on here a while ago.
here is when it happened. hahahaha
https://honda-tech.com/zerothread?id=617770
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow »</TD></TR><TR><TD CLASS="quote">Stock ls motor can be rev to 7500. Stock shortblock can be taken to 8000. </TD></TR></TABLE>
I could rev an LS bottom end to 10,000 RPM... But how long will it stay together? If you want to rev an LS block past 7200 or so I would at least balance the entire rotating ***'y and use ARP rod bolts. I don't believe that shot peening the rods is necessary for 8000 (or so) RPM.
