obd0 to obd1
Old Dec 25, 2003 | 08:47 PM
skrappy's Avatar
Default obd0 to obd1
i have the inside harnest and the engine harnest off an 92 civic ex i have a d15b vtec motor in my 89 hatch wiring is all messed up how hard is to replace both the inside and the engine harnest from an 89 to a 92 civic
Old Dec 25, 2003 | 09:35 PM
Redline130's Avatar
Default Re: obd0 to obd1 (skrappy)
Honestly, I think it would be easier and cleaner to use an 88-91 harness and use an OBD0 to OBD1 conversion harness. Try and find intact engine and interior harnesses and just replace your "mess" as you call it.
Old Dec 26, 2003 | 06:39 AM
kid-honda's Avatar
Default Re: obd0 to obd1 (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, I think it would be easier and cleaner to use an 88-91 harness and use an OBD0 to OBD1 conversion harness. Try and find intact engine and interior harnesses and just replace your "mess" as you call it. </TD></TR></TABLE>
Always use stock harnesses and add what you need.
Old Dec 26, 2003 | 08:49 PM
sloweredcivic's Avatar
i have done this swap you would be way better off to fix your current wiring and pay jason(blown hatch) i think is his name on here ofr a conversion harness. it works so much easier aside from the multipoint swap i only had to run like 7 wires 4 of those being the o2 for my z6 and i know use a p28 ecu.
Old Dec 26, 2003 | 08:50 PM
spartu5's Avatar
check out http://www.boomslang.us
Sherwin
Sep 19, 2012 10:27 AM
boomslang
Dec 6, 2010 09:37 AM
bobbyisking
Jul 7, 2008 09:22 AM
Hybrid
Jan 13, 2004 07:09 PM
