Finally got my header on!
Old Sep 24, 2001 | 09:46 AM
canuckr's Avatar
Default Finally got my header on!
After rain delays, rusted bolt delays, and other stuff I finally got the bugger in. Now my check engine light is on. How do I get it to turn off? I just put in a Spoon 421 and a test pipe. Thanks for the help.
Old Sep 24, 2001 | 09:49 AM
sgT's Avatar
sgT
Default Re: Finally got my header on! (canuckr)
To get the light to turn off put your cat back on.
Or remove the light bulb.
Old Sep 24, 2001 | 10:04 AM
CPR's Avatar
CPR
Can you post your impressions once you get it on the road? I've heard nothing but good things about the spoon 421...
Old Sep 24, 2001 | 10:07 AM
jond's Avatar
Default Re: Finally got my header on! (CPR)
Do you have a O2 sensor in the test pipe?
Old Sep 24, 2001 | 10:11 AM
Black R's Avatar
25 Year Member
get a godspeed test pipe or a high flow cat or change to obd1 ecu (no 2nd o2 sensor) ...
then reset the ecu and you're all set!
The computer must detect a change in the a/f between the two o2 sensors... if not, cel.
Oh wait, there's a third option: if your test pipe doesn't have a bung in it, simply take your 2nd o2 sensor and put it through the rubber plug it is coming out of up into the cabin of the car under your center console/ radio area. CEL gone!
Old Sep 24, 2001 | 10:26 AM
canuckr's Avatar
I am using a Godspeed test pipe, with the o2 senser in it. Is this a normal thing when changing headers and putting in a test pipe for your check engine light to be on? There is also a raddle near somewhere near the rear wheels, but its only there when I am not moving and at idle. I am going to go the muffler shop and have them look at it.
Old Sep 24, 2001 | 10:52 AM
Dropspeed's Avatar
Hey Canuck, Ot but did you head up to Redline of Friday? As i was about to pull in cars started coming out of everywhere. I assumed some of Royal Oaks finest asked people to leave?
Mattj
Old Sep 24, 2001 | 11:31 AM
canuckr's Avatar
I went to redline meet, and when you saw every pulling out, we were all going to rams horn to eat. we havnt been kicked out of there in a couple of weeks. I dont konw how many people will be there this week cause alot of us are going to import fest in toronto.
Old Sep 24, 2001 | 12:12 PM
onyx00's Avatar
canuckr,
The Godspeed pipe should not produce a check engine light. Your small piece of cat. in the test pipe may have come loose or fallen out which would explain why you are getting the check engine light. Call dan @ Godspeed and talk to him about it. And the Spoon 4-2-1 shouldn't produce any check engine lights either.
avotegra
Nov 25, 2008 04:23 PM
RyosukeFC3s
Apr 12, 2006 04:01 PM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
Adampops
Dec 21, 2001 11:23 AM
Mighty Mouse
Aug 25, 2001 09:30 PM
