Moisture in headlights... Any tips on getting rid of it?
Old Dec 25, 2003 | 03:27 PM
Kristo92's Avatar
Default Moisture in headlights... Any tips on getting rid of it?
Just like the thread title says. I have moisture in one of my headlights... Does anyone have any tips of getting that out? Thanks in advance
Kris
Old Dec 25, 2003 | 03:40 PM
ryanstev's Avatar
Default Re: Moisture in headlights... Any tips on getting rid of it? (Kristo92)
How about taking the bulb out, then using a straw to suck out the water when it's laying on the bottom of the light fitting.
Old Dec 25, 2003 | 04:21 PM
Kristo92's Avatar
It's not that much moisture. More like the lamps fog up.
Old Dec 25, 2003 | 04:24 PM
al_r's Avatar
Default Re: (Kristo92)
It shouldn't leak at all, but take both (or all three) bulbs out and shoot a hair dryer (on low) in there. Worked on another car for me...
Old Dec 25, 2003 | 05:16 PM
97lude's Avatar
Default Re: Moisture in headlights... Any tips on getting rid of it? (ryanstev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanstev &raquo;</TD></TR><TR><TD CLASS="quote">How about taking the bulb out, then using a straw to suck out the water when it's laying on the bottom of the light fitting.</TD></TR></TABLE>
yumm
Old Dec 26, 2003 | 01:05 AM
Kristo92's Avatar
I think i will try the hair dryer plan. I'm not thirsty enough to suck out the moisture through a straw....
Old Dec 26, 2003 | 08:41 AM
OTT's Avatar
OTT
I had the same problem quite a whilke back.
Its when the seal is not airtight on the plastic headlights.
Its easy to fix (though I liked ryanstev
's idea; minted!).
All you do is turn side + dip + Full beam on, wait 10mins for heat to evaporate moisture.
Then find where the case is cracked/split and seal it with silicone sealant! jobs a good'un.
Using a hair dryer wont work as they only steam up when the seal is broken and condensation appears when water moisture condenses on the cold surfaces within.
So just warm them up & seal them!
Old Dec 26, 2003 | 01:25 PM
ludeR917's Avatar
Default Re: (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">All you do is turn side + dip + Full beam on, wait 10mins for heat to evaporate moisture.</TD></TR></TABLE>
Old Dec 26, 2003 | 01:30 PM
silver97prelude's Avatar
I had a prob with a tail light fogging up, i put in in the oven on one of the lowest settings for a few minutes then sealed it up when I took it out
Old Dec 27, 2003 | 01:54 PM
OTT's Avatar
OTT
If I did that i'd probly forget about it and come back to find a goopy one!
JunTec
Lighting
20
Feb 5, 2008 01:24 PM
NoahOneill
Aug 29, 2005 01:41 AM
Acura_I-RS
Jun 10, 2004 01:41 PM
ep3hatchblack
Mar 20, 2004 12:14 AM
N1NjA TuRtLE
Nov 9, 2003 02:24 PM
