How to fix my antenna?
Old Sep 24, 2001 | 08:53 AM
99ITR_SC's Avatar
Default How to fix my antenna?
Remind me NOT to go through a carwash with my radio on....! My antenna is now quite bent (although I have manually straightened it), and the motor makes a knocking sounds when it is trying to pull the antenna down (it doens't go all the way).
What do I need to do? Replace just the antenna itself? Is this under warranty? Part #?
Thanks in Advance.
Old Sep 24, 2001 | 09:00 AM
IntegraT's Avatar
Default Re: How to fix my antenna? (99ITR_SC)
Remove it IMO
This is a cool idea - https://honda-tech.com/zerothread?id=69175
Incognito's Avatar
Antenna broken from car wash won't be under warranty.
The antenna assembly is 1 piece, with the motor and everything all in 1.
Old Sep 24, 2001 | 09:09 AM
99ITR_SC's Avatar
Default Re: How to fix my antenna? (Incognito)
You know how much?
Old Sep 24, 2001 | 11:18 AM
Dropspeed's Avatar
If it just a bent mast that easy to install in about 3 minutes, if you gears are stripped on the motor than you will need an assembly. If I had to GUESS????? I'd say the mast is in the$40 range and the assmebly $160-200 But you could just call the dealer and get the right price
Mattj
paniaguae640
Jul 27, 2009 08:28 AM
debogsr
Jun 3, 2004 10:30 AM
beaterman
Aug 20, 2003 05:50 PM
mamaboy
Jan 13, 2003 06:06 AM
