The Pr3 Crossover point is??
Old Sep 24, 2001 | 07:27 AM
Chris_'s Avatar
Default The Pr3 Crossover point is??
What is the stock Pr3 Vtec crossover.
I just got my pr3 in the mail today and it is hitting Vtec at 4800..
I thought it was suposed to be closer to 5500 or 5700..
Old Sep 24, 2001 | 07:29 AM
TypeR0207's Avatar
Default Re: The Pr3 Crossover point is?? (crxconnection)
I believe the PR3 and PWO are around 4,600 or so. Not until the next Gen. stuff did it switch to 5,700.
Ideally is probably around 5,300 or so.
Old Sep 24, 2001 | 07:59 AM
Davep's Avatar
pr3 and pw0 switch a 4800 rpm.
Old Sep 25, 2001 | 12:41 AM
HyperREV's Avatar
New User
my PR3 x-over is 5400rpms...
do you have the 8000rpm rev limit?
Old Sep 25, 2001 | 05:56 AM
91sifreak's Avatar
New User
Default Re: The Pr3 Crossover point is?? (HyperREV)
Mine kicks in at about 4800 and hit the rev limiter at 8000
Old Sep 26, 2001 | 08:15 AM
Jesse H's Avatar
Default Re: The Pr3 Crossover point is?? (91sifreak)
you may have an automatic ECU.
Old Sep 26, 2001 | 08:55 AM
MysteryWagon's Avatar
Default Re: The Pr3 Crossover point is?? (Jesse H)
he may, but I am not sure what the redline is on the auto. pr3 ecu, I do no that the crossover for the manual ecu is 4800 rpm with a red line of 8200
[Modified by ShaggenWaggon, 1:56 PM 9/26/2001]
Old Sep 26, 2001 | 09:06 AM
TypeR0207's Avatar
Default Re: The Pr3 Crossover point is?? (ShaggenWaggon)
Well, the one sitting under my desk here at work is going to have a 5,300 x-over, and 9,300 redline, and no speed limiter!!
Katmann to the rescue!! (He'll be re-programming it soon).
Old Sep 26, 2001 | 10:37 AM
gutted spec's Avatar
New User
Default Re: The Pr3 Crossover point is?? (TypeR0207)
I will trade you!!!!
Old Sep 26, 2001 | 12:16 PM
91sifreak's Avatar
New User
Default Re: The Pr3 Crossover point is?? (realdealb16)
Is the a way to tell if you have an auto or manual from looking at the internals. Two nights ago I really watched and the vtec does come on at 4800 rpm and since I have no tach other then the stock Si gauge cluster I can't really tell when the rev limiter comes on but it goes to 8000rpm and then a sec later it hits. I do believe that is the manual because the other one I have is and auto and it kicks on at around 4500 and the rev limiter is around 7800.
[Modified by 91sifreak, 9:18 PM 9/26/2001]
Old Sep 26, 2001 | 01:46 PM
RyanR's Avatar
Just pop off the cover of your ECU and look at the knock sensor board. It's the little board in the top left corner connect to the main board by a ribbon cable. There is either an MT or AT on the bottom right corner of the KS board. MT for manual, AT for auto.
Old Sep 27, 2001 | 03:35 AM
HyperREV's Avatar
New User
Default Re: The Pr3 Crossover point is?? (97TypeR_9)
i've also seen quite a few Auto PR3's with NO MT/AT inside... all the auto ECU's i've seen have 7500rpm rev limits, with 4400 or so X-overs.
if you find you are stuck with an Auto, i'd just simply get Katman to chip it to MT specs, there's quite a few good proggy's out there for PR3's... you pick the rev limit and vtec x-over
Old Sep 27, 2001 | 05:24 AM
91sifreak's Avatar
New User
yeah mine says MT, didn't know that, thanks. How much does Katman do the whole program upgrade for, too like a spoon or mugen copy program? Do they have a site?
Old Sep 27, 2001 | 06:41 AM
RyanR's Avatar
http://www.jdmhondaparts.com. Katman charges $155 for ECU reprogramming. I just got mine done this weekend by him. Gotta go pick it up and test it out.
Old Sep 27, 2001 | 08:28 PM
CRXBart's Avatar
Joe from HASport does a good job too. His site for reprogramming is locashracing.com if you didn't know. But I'm sure everyone allready knows that.
bigplayj17
Apr 9, 2008 12:43 AM
Crackback
Aug 19, 2006 04:54 PM
misfithamster
Sep 10, 2003 03:30 PM
HybridRexy
17
Sep 29, 2002 08:09 AM
00VTEC
Aug 7, 2002 08:42 AM
