Just bought zex kit need some info
Old Dec 24, 2003 | 10:05 PM
91hob20hb's Avatar
Default Just bought zex kit need some info
I just got my zex kit for xmas present and need to know if i need to retard the timing or advance it all. i have 90 hatch with the beater d15b1. i plan on running up 50 shot and even though the motor has 230xxx miles it was recently rebuitl about 10xxx so should i still be cautious and run smaller shot?
Old Dec 24, 2003 | 11:16 PM
skud_dusty's Avatar
Default Re: Just bought zex kit need some info (91hob20hb)
Retard the timing quite a bit, and buy some colder plugs. You don't want detonation
Old Dec 24, 2003 | 11:18 PM
Kutsuju_SLeePER is gay
Guest
Posts: n/a
Default Re: Just bought zex kit need some info (skud_dusty)
colder plugs
Old Dec 24, 2003 | 11:45 PM
wannab20hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skud_dusty &raquo;</TD></TR><TR><TD CLASS="quote">Retard the timing quite a bit, and buy some colder plugs. You don't want detonation </TD></TR></TABLE>
If its zex fogger kit you dont have to with the 50 shot but if is direct port then retard it about 2 degress. We just installed the zex fogger on a buddies car 2 weeks ago and hes runnin a 55 shot no problem. Just go by what the instruction manual says or asks a local shop who does extensive work with nitrous.
Old Dec 25, 2003 | 12:23 AM
skud_dusty's Avatar
Default Re: Just bought zex kit need some info (wannab20hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannab20hatch &raquo;</TD></TR><TR><TD CLASS="quote">
If its zex fogger kit you dont have to with the 50 shot but if is direct port then retard it about 2 degress. We just installed the zex fogger on a buddies car 2 weeks ago and hes runnin a 55 shot no problem. Just go by what the instruction manual says or asks a local shop who does extensive work with nitrous.</TD></TR></TABLE>
Thanks for clearing it up. I haven't actually used nitrous before, just trying to give him a general idea
Old Jan 6, 2004 | 06:53 PM
s2000june's Avatar
dont wanna steal the thread but does any 1 know how to reset the ZEX module??
Old Jan 6, 2004 | 06:57 PM
90JPRCRX's Avatar
Smells like Tuna
zex on a d15b1???????
is anything done to the motor ?
your running zex stock?
what kind of gains do you get out of something like this?
how long will the motor last if you dont abuse the zex?
Old Jan 7, 2004 | 08:38 AM
Guest
Posts: n/a
Default Re: Just bought zex kit need some info (88JPRCRX)
lol ur funny<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88JPRCRX &raquo;</TD></TR><TR><TD CLASS="quote">zex on a d15b1???????
how long will the motor last if you dont abuse the zex?</TD></TR></TABLE>
Old Jan 7, 2004 | 09:33 AM
90JPRCRX's Avatar
Smells like Tuna
Default Re: Just bought zex kit need some info (LHDEGUSDMVX)
Old Jan 7, 2004 | 10:50 AM
Yellb16crxsi's Avatar
just retard the timming 2 degrees and get colder plugs to be safe.
Old Jan 8, 2004 | 12:00 PM
HondaHatchling's Avatar
Default Re: (civicrida3)
the switch on the side of the zex box, the same one that you used to program the box.
Old Jan 8, 2004 | 12:03 PM
definitly get colder plugs but if your only going with a 50 shot you shouldn't have to retard the timing, but my best advice would be to just follow the directions, it should tell you which jets to use for the fuel, nitrous and what the timing should be set at.
175Shot4Door
Apr 4, 2006 06:53 PM
honkey2fly
Aug 3, 2003 09:38 AM
tmekjian
Jun 11, 2003 11:35 AM
Brett
Mar 6, 2003 08:10 AM
sicklexus1
Jan 29, 2003 03:30 PM
