CRX seats in CIVIC?
Old Dec 24, 2003 | 09:15 PM
Jet Black's Avatar
Default CRX seats in CIVIC?
Quickly:
Want to swap CRX seats in the civic. Cant seem to find a way to do it, but I keep hearing of ppl who have done it. HOW?????
I've tried/considered:
- lining up the civic mounts
- drilling the bottom of the crx seats (but this would require spacers)
- removing bottom metal pan from the seats and swapping...requires to tops to be swapped, but that's not possible either.
Old Dec 25, 2003 | 12:07 AM
wannab20hatch's Avatar
Default Re: CRX seats in CIVIC? (Jet Black)
SEARCH
Its been asked a million times.
Old Dec 25, 2003 | 01:08 AM
payneth's Avatar
anything is possible. shouldnt be too hard. search, im sure someone has done it. if you can fit s2k seats in a rex u can put rex seats in a civic. (jus my 2 cents)
Old Dec 25, 2003 | 06:29 AM
Jet Black's Avatar
Default Re: CRX seats in CIVIC? (wannab20hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannab20hatch &raquo;</TD></TR><TR><TD CLASS="quote"> SEARCH
Its been asked a million times. </TD></TR></TABLE>
I have....heck Iève posted the questing about 3 times. I never get a clear answer....I allways get changing answers.
I did find one that was posted since the last time I searched, it involves drilling the floor pans. I've been told you can mod the seat rails tho.
Old Dec 25, 2003 | 09:20 PM
eL_cArLos's Avatar
Hey just take out the middle beam that you bolt the seats to (with a grinder) and bolt the seats directly to the floor... I got some prleude seats in my ef hatch....
Old Dec 25, 2003 | 09:30 PM
T-Mo's Avatar
post some pics ef9***** (why you gotta be a ***** though?)
Default Re: (EF9*****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9***** &raquo;</TD></TR><TR><TD CLASS="quote">Hey just take out the middle beam that you bolt the seats to (with a grinder) and bolt the seats directly to the floor... I got some prleude seats in my ef hatch....</TD></TR></TABLE>
WRONG!!!
All you do is take the sliders off of your civic seats and bolt them to the crx seats and put them back in.
Old Dec 26, 2003 | 10:01 AM
eL_cArLos's Avatar
I dont have any pics I did it cause I am a tall guy and was too lazy to find out how to put the seats in without chopping things up....the whole thing about switching out the sliders I dont know if it will work.... The seats I have in my EF are Prelude seats so that is why I just bolted them to the floor....
Old Dec 26, 2003 | 11:48 AM
sohcvtec66
Guest
Posts: n/a
just keep your rails, and re"drill holes threw the metal of the seat u wanna mount on your rails, use spacer's, then bolt them in.. its not that hard i just had to find the right bolt thread and size at jerry's...good luck
Old Dec 26, 2003 | 10:19 PM
payneth's Avatar
post pics when ur done.
Old Dec 27, 2003 | 03:39 PM
Jet Black's Avatar
Default Re: (sohcvtec66)
I considered drilling the bottom of the crx seat and installing the civic rails...the problem is that a civic uses about 1 inch of spacing on the inside, so I'd need some maad spacers, and with the bottom of the seat beeing so thin I'd be afraid of it braking loose in an accient.
Thanks for the info guys, I guess I'll just forget about it....doesnt seem to be a simple answer.
Old Dec 27, 2003 | 04:06 PM
BlendedEJ8's Avatar
my friend did his, he just used the seat rails from the civic b'c the crx rails were too low for his taste. dont look bad though i guess. stil like the GSR seats better
Old Dec 28, 2003 | 12:55 AM
sohcvtec66
Guest
Posts: n/a
thing that suucks is crx seats, and civic rails bolt match bolt holes, and i know 89 civic with 90 crx si seats arwe a bitch to mount cuss,the passenger seat, the rail closer to the center console, doesnt evan make it flush with the seat or holes... fab new rails its soo much easyier then ****** arund with ef rails.
tougermoua
Feb 4, 2013 09:18 PM
.Thomas
20
Feb 9, 2005 09:47 PM
SlamedownCivic
Nov 22, 2004 07:31 AM
london_civic
Mar 14, 2004 05:13 PM
pinoyboy204
May 10, 2003 07:02 PM
