what cars distributors can i use on my b16a1
Old Dec 24, 2003 | 08:08 PM
typesguy's Avatar
Default what cars distributors can i use on my b16a1
i got a b16a1 in my rex and i need to know what honda's or acura's distributors i can use for ex. could i use a 92-93 teg gsr dizzy or a 90-93 teg ls dizzy or do i have to get one to a b16a1 cuz the b16a1 dizzy are kinda hard to find. someone help me out
Old Dec 24, 2003 | 11:51 PM
3rdGteg's Avatar
Default Re: what cars distributors can i use on my b16a1 (b16crx000)
I have a b16a1 distributor for sale. IM me if interested; also check my for sale thread:
https://honda-tech.com/zerothread?id=703827
Old Dec 25, 2003 | 06:02 AM
Patch's Avatar
What is wrong with yours? The guts of your B16A1 distributor are the same as the 90-91 Integra (igniter, coil, cap, rotor). If you need a new distributor (bearings are bad) then I believe a 90-91 Integra distributor will work, but you have to cut one of the legs of it off. I know the guts are interchangeable, but I've only read that the 90-91 Integra dizzy will fit.
Old Dec 25, 2003 | 03:15 PM
3rdGteg's Avatar
Default Re: what cars distributors can i use on my b16a1 (Patch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">What is wrong with yours? The guts of your B16A1 distributor are the same as the 90-91 Integra (igniter, coil, cap, rotor). If you need a new distributor (bearings are bad) then I believe a 90-91 Integra distributor will work, but you have to cut one of the legs of it off. I know the guts are interchangeable, but I've only read that the 90-91 Integra dizzy will fit.</TD></TR></TABLE>
OR without having to modify anything, buy the right distributer for your motor (the one I'm selling a couple of posts above^^)...B16a1 distributer.
Old Dec 25, 2003 | 04:02 PM
typesguy's Avatar
well i am currently still having a missing problem and i've replaced everything so i just just goona replace the whole dam distributor. soa 90-91 teg ls dizzy will work but i have to cut one of the legs off. so i will only have 2 bolt hold the dizzy on?
Old Dec 27, 2003 | 01:11 PM
typesguy's Avatar
ttt
Old Dec 27, 2003 | 01:31 PM
UofOImpressionZ's Avatar
I used my 90-91 Teg distributor on my B16a1, but only one of the bolts actually hold it on, I don't recomend it for a permanant fix, but it defenately works. Just lop off one of the ears and bolt it up.
Old Dec 27, 2003 | 07:49 PM
typesguy's Avatar
what about a 88-89 integra engine's dizzy i think the engine is a zc would that one work
Old Dec 31, 2003 | 12:42 AM
typesguy's Avatar
bump
Old Dec 31, 2003 | 01:04 AM
Katman's Avatar
Default Re: (b16crx000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crx000 &raquo;</TD></TR><TR><TD CLASS="quote">what about a 88-89 integra engine's dizzy i think the engine is a zc would that one work</TD></TR></TABLE>
nope, an 88-89 integra distr. won't work.
If you wanna do it right, find an 89-91 (1st gen) b16a distributor, such as the one 3rdGteg
is selling . There are no optional US distributors that match the physical make up/body design of a 1st gen b16 distributor. Your only alternative is to hack up a 90-91 LS distributors mounting legs or find a genuine 1st gen b16 distr.
Old Dec 31, 2003 | 03:14 AM
sirminder's Avatar
Default Re: (Katman)
what about using the insides (coil, ign. etc..) of any other vtec distributor and keeping the plugs and housing? Arent all vtec dist. the same?
Old Dec 31, 2003 | 09:31 AM
Katman's Avatar
Default Re: (sirminder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirminder &raquo;</TD></TR><TR><TD CLASS="quote">what about using the insides (coil, ign. etc..) of any other vtec distributor and keeping the plugs and housing? Arent all vtec dist. the same?</TD></TR></TABLE>
yes, as far as internals go, you can even use SOHC ignitor and coil in a B16 distributor.
All DOHC vtec distributors are the same, respective to their OBD type.
Old Dec 31, 2003 | 01:33 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
is selling . There are no optional US distributors that match the physical make up/body design of a 1st gen b16 distributor. </TD></TR></TABLE>Yeah, what Katman said.
Ya'll know Katman don't lie
Old Dec 31, 2003 | 03:35 PM
typesguy's Avatar
thanks guys ill just try to find a 1st gen distributor
Old Dec 31, 2003 | 09:42 PM
spnfed's Avatar
I'm selling one right now on ebay for reall cheap.
It's off of a 89 B16A1.
1badcrx
Jun 6, 2009 05:01 PM
posaccord01
Mar 22, 2007 03:59 PM
LSV_REX
Jul 1, 2005 09:11 AM
