ECU problem for a swap
Old Dec 24, 2003 | 06:37 PM
PinoyB18A's Avatar
Default ECU problem for a swap
Okay, here's the burning topic and question:
I have a 90 CRX HF. I am trying to put an LS motor in it. I was told by someone that I need the PR4 ECU to get this thing running. I tried plugging it in but the plugs do not match. The harness has 2 black plugs and 1 white plug. The "holes" in the harness look like they are in a straight line like this:
_ _ _ _ _ _ _ _ _ _ _
The PR4 ECU's metal connections are kinda un-aligned like this:
-- -- _ _ _ _ _ _ -- --
Am I doing something wrong? Do I have the right ECU? Is my CRX HF equipped with the wrong harness? Please let me know...
(619) 549-0158
PinoyB16A@yahoo.com
Modified by PinoyB18A at 3:48 AM 12/25/2003
Old Dec 24, 2003 | 08:02 PM
Redline130's Avatar
Default Re: ECU problem for a swap (PinoyB18A)
What year is the ecu from? If it's a 92 or 93 model, then the harness connectors won't fit. If the ecu is from a 90 or 91 car, then the connectors should fit.
legend99
11
Apr 3, 2012 04:47 AM
1bad_crx
Apr 8, 2003 03:37 PM
