Misguided on EF/B-Series swap
Old Dec 24, 2003 | 06:32 PM
PinoyB18A's Avatar
Default Misguided on EF/B-Series swap
Okay, here's the burning topic and question:
I have a 90 CRX HF. I am trying to put an LS motor in it. I was told by someone that I need the PR4 ECU to get this thing running. I tried plugging it in but the plugs do not match. The harness has 2 black plugs and 1 white plug. The "holes" in the harness look like they are in a straight line like this:
_ _ _ _ _ _ _ _ _ _ _
The PR4 ECU's metal connections are kinda un-aligned like this:
_ _ _ _
_ _ _ _ _ _ _
_ _ _ _
_ _ _ _ _ _ _
Am I doing something wrong? Do I have the right ECU? Is my CRX HF equipped with the wrong harness? Please let me know...
(619) 549-0158
PinoyB16A@yahoo.com
Modified by PinoyB18A at 3:46 AM 12/25/2003
Old Dec 24, 2003 | 06:33 PM
PinoyB18A's Avatar
Default Re: Misguided on EF/B-Series swap (PinoyB18A)
Actually it's more like this:
-- -- _ _ _ _ _ _ _ -- --
Sorry about that...
Old Dec 24, 2003 | 06:54 PM
USDMMARK's Avatar
is the pr4 obd1? or is it obd0 what years did it come out of
Old Dec 24, 2003 | 07:37 PM
NCchris's Avatar
You need the 90-91 pr4, it is pre obd. The 92-93 pr4 is obd1 and has the different plugs. I have a 91 pr4 in my 90 hf. FWIW, the ls will crank and run with the hf ecu. Don't think the hf ecu has agressive enough fuel maps to run the b18 without being really lean.
HTH
chris
93siturbo
Apr 10, 2009 06:22 PM
PinoyB18A
Dec 24, 2003 08:02 PM
-slow ej-
Nov 20, 2003 11:37 AM
