Anyone know how to remove the A/C belt?
Old Sep 24, 2001 | 04:38 AM
MPH's Avatar
MPH
New User
Default Anyone know how to remove the A/C belt?
Besides cutting it.
Old Sep 24, 2001 | 04:56 AM
sgT's Avatar
sgT
Default Re: Anyone know how to remove the A/C belt? (MPH)
Try loosening the tensioner pulley.
You will also have to unbolt the supplementary mount to remove the belt.
Dropspeed's Avatar
Unfortunatly you must remove or at least loosen the lower engine mount that the belt goes around if you want to take it off. A little trick if you just trying to make some power for a track event. Take the power steering belt off. loosen the a/c belt then remove it from the crank pulley, after its loose move it over so its on the engine mount and pull it up and hook it aroung the power steering pulley, tighten it down and its out of the way.
Mattj
Old Sep 24, 2001 | 05:20 AM
MPH's Avatar
MPH
New User
Default Re: Anyone know how to remove the A/C belt? (Dropspeed)
Thanks!
Old Sep 24, 2001 | 05:39 AM
DutchITR1689's Avatar
Mattj
Haha.. The more you turn your steering wheel the cooler it get... (A/C driven by Power steering pump)
immajackuup
10
Dec 22, 2025 08:55 PM
redm3turbo
Aug 18, 2015 04:59 PM
x_tuh_sy
Nov 19, 2007 11:27 PM
luderollin
Feb 25, 2005 12:07 PM
hybrider
Jul 28, 2002 08:05 PM
