Someone explain: dual valve springs
Old Sep 23, 2001 | 10:17 PM
mike's Avatar
H-T Order of Merit
Default Someone explain: dual valve springs
I have a couple of b21a's. They have two springs per valve, one inside the other. Is there a benefit from having daul valve springs?
Thanks,
Mike
Old Sep 24, 2001 | 12:02 AM
ImportReview
Guest
Posts: n/a
Default Re: Someone explain: dual valve springs (mike)
Yes, they go double because they are way stiffer, usefull for VTEC motors that rev high...you need stiffness for high RPM so the spring can rebound back to full length before the next downstroke.
Jeff
Old Sep 24, 2001 | 12:22 AM
mike's Avatar
H-T Order of Merit
Default Re: Someone explain: dual valve springs (ImportReview)
These are definitely not vtec motors. They are from 91 preludes, b21a1a.
Old Sep 24, 2001 | 11:30 AM
JG Luder's Avatar
you are correct, the cams only have 16 lobes...
so basically still what Jeff said minus the VTEC part.
A13sechatch
Dec 3, 2008 05:30 PM
TehMan
Feb 20, 2006 08:00 AM
HmgLauj69
Sep 8, 2004 11:52 AM
thunteg
Aug 4, 2004 01:05 PM
