b16a trouble ?
hmm...OBDI or OBDII?
Do you have a B16A ecu?
Well..what do you need to know?
Here's a mini wiring guide (taken from http://hybrid.honda-perf.org/tech/info.html#B16Aeg6 )
Description -- wire color -- ECU side pin number
VTEC Solenoid -- Yellow/Green -- A4
VTEC Oil Pressure Sensor -- Blue (passenger side harness) -- D6
VTEC Ground -- Black chassis -- ground
Knock Sensor -- Red/Blue -- D3
Evap Purge Power -- Yellow/Black -- 12V power (hot in ON or START)
Evap Purge Solenoid -- Red -- A20
Hope that helps.
Hope that helps.
I have no b16a ecu I have a 91 crx si ecu that I am using the b16a1 is from a 91 sir I am hopefully going to get a ecu from hondata or zdyne ecu. how would I wire it up
NstyGrnHatch
10
Jan 30, 2010 07:09 AM
