b16a1 wiring for a 88 crx
New User
I have a 91 crx si ecu and I have no idea how to wire up the ecu to the engine for a good operation, I have the stock wiring harness and bought a vtech controller. The 91 si ecu has had the rev limiter and the speed governor taken out. I could use some good help in the problem or situation, so thanks for your time.
Re: b16a1 wiring for a 88 crx (hondasir1988)
I think http://www.hasport.com might have something to make it eaiser. I'm not to sure though.
are you asking how to wire the b16a ecu in or a vtec controler?
if its the vtec controler they make all ready fabricated wire harnesses for them but they are not that hard to install anyways. if its a feilds just go to http://www.inlinefour.comto see the harness.
If its the ECU you are talking about you really only need to tap in 4 wires vtec ground, vtec selonoid, vtec oil pressure sensor, and a knock sensor. HAspots also makes a pre fabricted harness for that 2.
ExodusJKD
08-05-2005 07:57 AM
juicy.koreans.suck
12-26-2001 09:34 AM
