Should I display the A/F ratio If .....
Hey Guys,
Real easy one I've been on the fence about. I'm getting me car hondata tuned (s200b w/datalogging) and I was looking into getting a wideband 02 setup. I know this is not necessary because when I'm at the dyno, shes getting tuned via a wideband. I mean its good to monitor everything, but do you think I'm waisting my $ if I go with a FJO/TechEdge, etc setup?
The only reason I see the A/F #'s changing slightly is for seasonal temperature, but I'm sure the Hondata can compensate for these changes.
Thanks
Thanks
Well the AF ratio wont change that much with the seasons.......I think BoostedHybrid had a post on this. Ill search for you. Anyway I think after its tuned you could spend that money on something else, instead of a wideband unless you plan on tuning friends cars also.
I couldnt find the link, but I would PM Boosted Hybrid. Since he is in PA he could tell you how much of a difference he sees in AF ratios through the seasons, since he definitely gets all 4 like you do in NY.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">On the same boat as Fred
Up for more opinions!
wow me too.. bump
</TD></TR></TABLE>wow me too.. bump
