VTEC WIRE IS CUT
Old Dec 23, 2003 | 09:14 PM
eazye5591's Avatar
Default VTEC WIRE IS CUT
OK MY CAR CAME WITH A D15B8 WHICH IS THE CX MOTOR RATED At 60hp 8 valve and now i got jdm d15b motor in it with vtec but now i need help on the vtec , on the vtec solenoid theres a wire and its cut and on wires that plug into the distributor theres the same color wire thats also cut so my question is can i just strip both wires and tie them up together so my car can run vtec? also i got a jdm vtec ecu already
Old Dec 24, 2003 | 12:20 PM
eazye5591's Avatar
Default Re: VTEC WIRE IS CUT (eazye5591)
ne 1?
Old Dec 24, 2003 | 03:54 PM
mastarolla's Avatar
solder them
also....do you have the vtec pinout wired up for the vtec ecu? You can drop the motor in and hook the ECU up but without the vtec signal wire going anywhere, it wont do any good.
Old Dec 27, 2003 | 03:22 AM
Xsi's Avatar
Xsi
Yes, as long as you know which wire goes where just strip the wire back and solder them together.
jetoutant
11
Jan 2, 2008 07:50 PM
sammydigital
Jun 9, 2006 05:31 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
