a stupid question
Old Dec 23, 2003 | 08:36 PM
sleepyhamsterlx's Avatar
Default a stupid question
to end a arguement between this guy at a "shop"<<<Uncle Bens ricer town place. the guy said that you don't have to do anything to the head if you get oversized pistons, so what about that. Isn't it obvious that you have to match the bottom of the head to the Circumference of the bore on cylinders. Correct me if im wrong. Im talking about maybe 85mm sized pistons
Old Dec 23, 2003 | 08:48 PM
99blackcivicSi's Avatar
Default Re: a stupid question (Mgnlxsd)
Yes you should for optimal power but it isnt nessicary, B16 head (81mm) b20 bottom end (84mm) people do it all day long no probs if you want to go ahead if you don't nothing is going to hurt it
Old Dec 24, 2003 | 06:47 PM
Default Re: a stupid question (99blackcivicSi)
so it doesn't matter, i thought it would cause some major engine damage if you don't match up the bottom of the head w/ the Circumference of the block. So are there any noticeable gains if doing so or any problems that may arise
Old Dec 25, 2003 | 12:10 AM
kinesistech's Avatar
yeah, it'll definetly make a difference. The sharp edges on the head can be a possible source for hotspots that may cause detonation. If you dont do it then you can still use the head on a normal bore engine in the future. But if you do it the head will be limited to big bore engines only.
Old Dec 25, 2003 | 07:35 AM
Default Re: a stupid question (kinesistech)
OK, for example; i get a b16a2 swap in there and i want oversized pistons and a bottom end done. I can just take off the head and don't worry about the valve area being to small and not matching up to the oversized pistons. im still confused about all this and im trying to learn this stuff.
Old Dec 25, 2003 | 07:57 AM
like in this pic in the upper right corner doesn't the circumference of the bottom end of the head have to match up w/ bore on say an engine like this. Thats the problem im having because if the bore is bigger than the unmodified head i obviously think that it will break. Please clarify more thank you.
Old Dec 25, 2003 | 09:45 AM
highbrid's Avatar
the pistons do not make contact with the head. the piston's edges do not go above the deck of the block, therefore that is why you can run a b20 block with a b16 head. It is not necessary to modify the head, which is why most guys do not do it.
Old Dec 25, 2003 | 09:47 AM
Default Re: a stupid question (highbrid)
thanks
JRSC01GS-R
Engine Machining & Assembly
Jun 6, 2015 02:40 AM
ActiveAero
Feb 4, 2003 03:22 PM
turboex
Nov 11, 2002 11:43 AM
supanatural
Apr 23, 2002 10:30 AM
clockworks
Sep 21, 2001 12:25 PM
