just swap a zc motor, clutch won't engage
after finishing my swap i turn on the motor and let it warm up for about 20 min. i then decided to take it out for a spin. put it into first gear let go of the clutch, nothing happens. it seem like i was still in nuetral. tried all the gears ended up with the same results. i can actually move from gear 1,2,3,4, and 5 without using the clutch. i don't know what is wrong with it. i've already bleed the clutch line. so if anyone can help out please do. i am still very new to these stuff. thanks
bled the clutch line? what the hell. zc's are cable i dont know what you bled but you better get some fluid in there. also try adjusting your clutch cable. does the clutch feel normal? did you hook it up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">bled the clutch line? what the hell. zc's are cable i dont know what you bled but you better get some fluid in there. also try adjusting your clutch cable. does the clutch feel normal? did you hook it up?</TD></TR></TABLE>
i'm thinking the same thing too..how do you bled a cable tranny? lol..do what he say and check the clutch cable and see if you have titen it...this is probably a stupid question but did you even installed te clutch? or the clutch fork? or is the clutch new or at least still close to new?..
If u look at his SN, it appears he has a CX (which explains this bleeding of the clutch line). ZC's also came in EG's (obd-1) so they did come with a hydro tranny. A friend of mine has the swap in his EG. CX guy just posted in the wrong forum.
canada also had a CX which was an EF. that would make more sense since its the EF forum hes in. all EFs have cable trannies but ill guess well never know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">CX guy just posted in the wrong forum.</TD></TR></TABLE>
djsire
Sep 7, 2005 04:14 PM
