what setup for me???
Old Dec 23, 2003 | 03:49 PM
Mr.c's Avatar
Default what setup for me???
first i am only going to spend 3500 on my engine all to gether i am thinking lsvtec but have heard mixed fillings about this please teach me
ps: i am also condsedering built b16 iowboost b16 or lowboost ls
Old Dec 23, 2003 | 03:52 PM
Miracle_X_Bar's Avatar
Default Re: what setup for me??? (Mr.c)
go b16 all motor!!!! or go GSR...ls/crv-tech is good too, but, can be pricy. What motor do you have now or what exactly are you working with???
Old Dec 23, 2003 | 04:08 PM
granada_sun's Avatar
ls/vtecs can be nice if they have high end parts invested, like any other motor, plus the labor needed to throw one all together correctly can run high in costs.
For the money spent on a gsr swap, you could get a b16 and use the $1k leftover to give you more power than the gsr. But either one are good swaps.
LS turbo set up isn't a bad idea either, but again, they can be costly, it all depends on what you want for power, and how much you have to work with.
hth
Old Dec 23, 2003 | 06:30 PM
Mr.c's Avatar
Default Re: what setup for me??? (Miracle_X_Bar)
right now i got nuttin but by spring i should have 8k but this is not only a drag car i want a car thet handels too
Old Dec 23, 2003 | 09:11 PM
that means u got plenty of time to do some homework and look into the set up that you want.
search button works wonders meng....
read up on costs and set ups and what swaps do what etc etc. basically its like home schooling, but no annoying teachers, hehe
Old Dec 23, 2003 | 09:17 PM
jaydmcrx's Avatar
If you hunt and find stuff you will be ok. If you get a whole b16swap, 1150. And then you find a b17crank and rods. And some ctr cams and pistons. You are golden! Tune too.
Old Dec 24, 2003 | 07:10 AM
Mr.c's Avatar
Default Re: (jaydmcrx)
the cheapest b16 i have seen was for 1200 for motor ,ecu,and trans
thanks for the input
Old Dec 24, 2003 | 08:12 AM
Mr.c's Avatar
Default Re: (Mr.c)
bump please help with info
Old Dec 25, 2003 | 05:49 PM
jaydmcrx's Avatar
http://www.jdmshit.com has them for 1150 or 1250 for motor tranny ecu axles ect...
HondaTeKnology
54
Jan 4, 2008 08:16 PM
mra4886
Oct 30, 2006 08:17 PM
jdmsiblue1
Jan 30, 2006 06:06 PM
boostedeghatch
May 6, 2005 04:54 AM
kaoss_11
Dec 2, 2004 12:12 PM
