92-93 Integra RS Transmission Work on B18C1
Old Dec 23, 2003 | 12:51 PM
civicqm's Avatar
Default 92-93 Integra RS Transmission Work on B18C1
Just as it says will a 92-93 Integra RS Tranny work on a B18c1? I think that the RS had a B18b but I am not sure. Anyone know??
Old Dec 23, 2003 | 01:02 PM
Benny Hinn's Avatar
Default Re: 92-93 Integra RS Transmission Work on B18C1 (civicqm)
Yes it will.
Old Dec 23, 2003 | 03:28 PM
civicqm's Avatar
Anymore thoughts????
Old Dec 23, 2003 | 03:47 PM
Benny Hinn's Avatar
Longer gearing compared with either the 92-93 GSR or the 94-up GSR.
What else are you asking?
Old Dec 23, 2003 | 06:59 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicqm &raquo;</TD></TR><TR><TD CLASS="quote">Just as it says will a 92-93 Integra RS Tranny work on a B18c1? I think that the RS had a B18b but I am not sure. Anyone know?? </TD></TR></TABLE>
Will it bolt onto the B18C1 motor and work? YES
Is the gearing appropriate for a B18C1 motor? NO
Hopefully you will be using this in an 88-91 Civic/CRX or a 90-93 Integra that originally came with a cable tranny. The 90-93 LS, RS and GS had the B18A1 and a YS1 tranny. The 92-93 GSR also had the YS1 tranny, but with shorter gears. That would be better for the B18C1 but they are very hard to come by. I'm glad I got mine
Old Dec 24, 2003 | 10:06 AM
acy76's Avatar
Default Re: 92-93 Integra RS Transmission Work on B18C1 (VTECVillain)
Just a quick correction - the 90-91 integra transmission is not the YS-1 - it is the A1 or S1 I believe, depending on year. At any rate, the clutch disc is splined differently for the earlier transmissions, as they have a smaller diameter input shaft (the disc is the same for 92 and up, hydro and cable I believe), something to keep in mind. Also, for gear swapping possibilities and overall strength, the YS-1 is a better unit. Basically a cable case with hydro internals.
Old Dec 27, 2003 | 02:54 PM
irev210's Avatar
Default Re: 92-93 Integra RS Transmission Work on B18C1 (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">Just a quick correction - the 90-91 integra transmission is not the YS-1 - it is the A1 or S1 I believe, depending on year. At any rate, the clutch disc is splined differently for the earlier transmissions, as they have a smaller diameter input shaft (the disc is the same for 92 and up, hydro and cable I believe), something to keep in mind. Also, for gear swapping possibilities and overall strength, the YS-1 is a better unit. Basically a cable case with hydro internals.</TD></TR></TABLE>
yup, it is a hydro inside...
you can take the shorter gears that are in a YS1 and put it into a 98 spec ITR with a 4.785 final drive and have one short tranny!
98tegfreak
Aug 8, 2007 06:44 AM
be18see1
May 29, 2007 07:44 PM
OneCamIsEnough
Oct 15, 2004 09:52 AM
EF4lyfe
Jan 30, 2004 11:58 PM
