Changing front brake pads on a 92 Accord
Old Dec 23, 2003 | 12:49 PM
William G's Avatar
Default Changing front brake pads on a 92 Accord
Can anyone tell me if this is a fairly easy task and what tools I may need to do the job properly?
Thanks
Will
Old Dec 23, 2003 | 12:54 PM
.bagged's Avatar
Default Re: Changing front brake pads on a 92 Accord (William G)
fairly simple...10mm wrench and if my memory is correct a 12mm for the caliper..dont quote me on that..
Old Dec 23, 2003 | 12:56 PM
William G's Avatar
Default Re: Changing front brake pads on a 92 Accord (bagged93accord)
Wow, doesn't sound difficult at all. Can you tell me about how long the process takes?
Old Dec 23, 2003 | 12:59 PM
.bagged's Avatar
front brakes only....30 min. just take your time though..do you have a haynes manual..?
Old Dec 23, 2003 | 01:02 PM
William G's Avatar
No manual but I do have a handy digital camera to take pictures of each thing I do along the way incase my geek *** forgets something. I did when i changed the heads on my buell and didn't have any problems. *fingers croessed*
Old Dec 23, 2003 | 01:58 PM
.bagged's Avatar
if you can work on a bike like that you will be just fine...
Old Dec 24, 2003 | 11:00 AM
RotaryBzzzz's Avatar
add in a jackstand (or a cardboard box) to hold the caliper in the air while your changing the pads. Don't let them hang.
I would also add some kind of pry (cresent wrench is what i use: whatever is handy) into the mix to use to push the piston back in. Use the old brake pads to cushion it like this:
|---|<---piston
----- <---old brake pad
O--- <- tool pushing towards piston
----- <---other side of caliper
Old Dec 24, 2003 | 12:02 PM
.bagged's Avatar
Default Re: Changing front brake pads on a 92 Accord (RotaryBzzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">add in a jackstand (or a cardboard box) to hold the caliper in the air while your changing the pads. Don't let them hang.
|---|&lt;---piston
----- &lt;---old brake pad
O--- &lt;- tool pushing towards piston
----- &lt;---other side of caliper
bump..
Old Dec 25, 2003 | 02:29 PM
iam7head's Avatar
do it the right way, the rotor need to turn
Old Dec 25, 2003 | 08:19 PM
William G's Avatar
Default Re: Changing front brake pads on a 92 Accord (iam7head)
Are the rotors easy to remove and bring somewhere to have them turned?
Will
Old Dec 25, 2003 | 08:23 PM
Riceburner247's Avatar
I forget with the accords, but you either unbolt a couple screws, or just pull really hard, or both.
Old Dec 26, 2003 | 04:59 AM
The_Todd's Avatar
Farts in the shower
Default Re: Changing front brake pads on a 92 Accord (riceburner247)
And make sure to check your rears since your fronts need replacing...just a rule of thumb, and other brake components...it works as a system hence brake system.
Old Dec 26, 2003 | 12:20 PM
William G's Avatar
Default Re: Changing front brake pads on a 92 Accord (VRDrvr)
Thanks again for all the helpful info, guys!
Old Dec 26, 2003 | 07:53 PM
v4lu3s's Avatar
RTFM
i NEVER turn 90-97 accord rotors unless they are showing signs of grooving...why encourage wapred rotors?
also when doing front pads on accors i never have to mess with hanging the calpier by anything, i jsut unbolt the bttom bolt and rotate the caliper up, pull the pads spray with brake clean slide new pads in and botl it back up.
its about a 25 minute job with most of it jackign the car up and pulling tires.
Old Dec 27, 2003 | 05:50 PM
The_Todd's Avatar
Farts in the shower
Default Re: (v4lu3s)
Just curious how would turning your rotors cause warping? And the brake clean stuff works great and might as well do it since all is off
snaylor
Aug 26, 2017 05:36 AM
Newbie808
Suspension & Brakes
Mar 7, 2012 02:51 AM
St3v3
Dec 2, 2007 08:59 PM
2kstreetcivic
25
Jan 27, 2005 02:52 PM
clean
May 9, 2002 03:49 AM
