Relocating ECU...Extending harness. Questions!
Old Dec 23, 2003 | 09:45 AM
Jonathan_ED3's Avatar
Default Relocating ECU...Extending harness. Questions!
I want to relocate my ECU to free up some airspace in my kickpanel area and also to make the ECU a little easier to access once I have new carpet and speakers in.
Will extending the wires a few inches directly in front of the ECU plugs adversely affect anything?
Anything I should take special precaution with? I'm going to pull the ECU pins out of the harness before I make the extension so there will be only one solder joint, and everything will be shrinkwrapped afterwards.
Thoughts? Concerns?
TIA.
Old Dec 23, 2003 | 09:42 PM
Colin's Avatar
Default Re: Relocating ECU...Extending harness. Questions! (Jonathan_EH)
nope, a couple extra inches won't make a difference.
Seems pretty straight forward... just the obvious stuff:
-make sure you use the same or larger gauge wire
-make sure your solders are good
-make sure there are no exposed wires..... just all that stuff you already know
Old Dec 23, 2003 | 11:23 PM
Default Re: Relocating ECU...Extending harness. Questions! (91IntegGS)
Thanks for the reassurance.
slogfilet
10
Aug 18, 2014 06:55 AM
GSRacer1
Apr 21, 2004 04:24 AM
USDM 4G VTEC
Apr 9, 2003 07:34 PM
EGHatchy
Jul 1, 2002 07:30 AM
