does cross drilled rotors affect the brake pad wear?
I was thinking of getting cross drilled rotors but i was wondering how does it affect the break pad wear? does it wear the same or does it wear faster?
If they are not properly drilled (like most of the ones out there) they can decrease brake pad life and possible make your rotor crack.
don't be fooled by the "brembo cross drilled" rotors, most of the time it's just brembo blanks that some shop drilled into
any drilled rotor will wear your pads, true cross drilled rotors are actually "cast" in the mold with the holes in them and the holes are rounded at the edge
cross drilled rotors are good fro one thing, trapping pad and rotor material in the holes
they are also prone to crack
get yourself blanks and be done with it, cross drilled and slotted rotors are things of the past when pads had huge amounts of gases that would build up in-between the pad and the rotor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanlegend21 »</TD></TR><TR><TD CLASS="quote">any drilled rotor will wear your pads, true cross drilled rotors are actually "cast" in the mold with the holes in them and the holes are rounded at the edge
get yourself blanks and be done with it, cross drilled and slotted rotors are things of the past when pads had huge amounts of gases that would build up in-between the pad and the rotor</TD></TR></TABLE>
For steet cars or race and street cars? I think they do have some practical ap's for racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanlegend21 »</TD></TR><TR><TD CLASS="quote">nope, not even for racing anymore</TD></TR></TABLE>
yes. porsche cup cars come new from the factory with crossed-drilled. Guys competing with them switch to solids...
The only app i could see is in competition drag where weight is a factor. But then again, you'd be machining them down anyway...
the way it is.. if you have a tendency to leave your foot on the brake while at a red light Orr stop or something you keep all the heat from pads and rotors together so cross drilled rotors stay cooler, so you don't warp them so fat. they also help to let gases pass threw as previously stated, but slotted rotors are for race more then street not like the other guy said... the reason they are slotted is so they can cut into the pad to allow fresh material to brake with..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznchino16 »</TD></TR><TR><TD CLASS="quote">so where can u get REAL BREMBO CROSS DRILLED</TD></TR></TABLE>the only rotors brembo cast with cross drilling are there gt kits...all oem style brembos are sold as blanks...other companys do the drilling ..ive had mine on for a year now and they hold up ok
I've had the sloted rotors and the cross-drilled rotors. My slotted rotors destroyed the pads in no time at all. The cross-drilled rotors have been holding up really well. Check with the Accord Store, they had a package deal on oversized, cross-drilled rotors, pads, and new brackets. Make sure of the type of calipers you have before ordering, or you might end up with something you can't use.
what happen is that alot i mean alot of guy i know that runs drilled rotor is cracked in no time, even brembo's crack.
If you plan to upgrade your rotor and you are not pushing almight 300whp, just get brembo blanks, if you pushing that much power, you should be using stock sized rotor anyways
Modified by iam7head at 11:03 AM 12/25/2003
That is true....but I plan to get pretty close to that, although not with the setup I have listed in my sig. In fact I'll probably be upgrading power before the brakes anyway, cause those gt kits are expensive...and I'm not exactly heavy on cash. This is going to be a slooooowwww process. Right now I'm starting to look for some decent, low priced 17s, cause my cash level is pretty close to that range.
dragonkx
13
Jun 29, 2010 07:37 AM
BrakeExpert
Suspension & Brakes
17
Oct 30, 2008 04:18 PM
WRXRacer111
Aug 1, 2002 10:58 AM
