How much boost can a d16 stock piston take?
Old Dec 23, 2003 | 08:47 AM
Sinner's Avatar
Default How much boost can a d16 stock piston take?
I hear the rods goes first at around 250+ hp. How much can the piston take before it melts?
Nick
Old Dec 23, 2003 | 08:54 AM
Hoodwinked's Avatar
Default Re: How much boost can a d16 stock piston take? (Sinner)
It is not necessarily the amount of horsepower that melts a piston, it is the tuning. If you are detonating, your piston will fry. If it is tuned right, your piston can withstand a decent amount of HP. Some boost anywhere from 6 to 12 psi on stock internals. IMO, I wouldnt go past 10 on stock internals.
Old Dec 23, 2003 | 09:57 AM
Quad-Damag's Avatar
Default Re: How much boost can a d16 stock piston take? (Hoodwinked)
12 can be done with the right tunning, most people i know run 9 psi daily driven and up it to 10 or 11 at the track
Old Dec 23, 2003 | 10:52 AM
thad
Guest
Posts: n/a
lol boostedED9 ran 16.5 on stock internals (D16)withthe exception of arp headstuds and a 2mm headgasket. he made 300 some whp and ran an 11.8
Old Dec 23, 2003 | 11:58 AM
ladysman's Avatar
Default Re: (thad)
I have run 13lbs all summer long all on stock internals (No headgasket, no studs, nothing). All Hondata tuned by myself. The thing runs like a dream and screams. No dyno runs because there isn't one close to me and I have no time to drive it somewhere. A shop somewhat close is getting one as I type so I will hopefully dyno before it gets pulled apart for the motor install.
Old Dec 23, 2003 | 01:39 PM
Jared's Avatar
Default Re: (ladysman)
good friend of mine ran 20psi all the freakin time on a stock d16a6 until he bent two rods, and that was with a td04.
Old Dec 23, 2003 | 03:22 PM
Drew Peacock's Avatar
Default Re: (Jared)
Yeah it the rods you have to worry about, around 240whp seems to be about as high as you can go before almost gauranteeing your engine won't last very long..
masterEF
Nov 10, 2009 05:56 PM
Briang3a3
Jan 17, 2008 04:10 PM
VolkswagenWHO!!!
Sep 11, 2006 05:51 PM
QwkD16
Dec 5, 2005 02:39 PM
itr1236
Mar 10, 2002 05:18 PM
