HELP PLEASE!!!!! MAIN RELAY TROUBLE
Old Dec 22, 2003 | 11:29 PM
wolf3007's Avatar
Default HELP PLEASE!!!!! MAIN RELAY TROUBLE
hello, i got a zc turbo, i swaped it into my crx si and when i put the key in the igntion the main relay starts to click rapidly( right next the the fuse box) and the ecu flashes everytime it clicks, some times it stops and starts back again , i checked the grounds and they are all fine, i also checked if the engine was getting spark and it dose, the fuel dose nto come on.i fugured it had to do with the relay. i tired another relay and it is dose the same thing, i even tired swapping the ecu out same theing. before the swap it was workign fine. please help..
Old Dec 23, 2003 | 01:32 AM
brentmc79's Avatar
Default Re: HELP PLEASE!!!!! MAIN RELAY TROUBLE (wolf3007)
Check you fuses, and check any wiring that was modified or disturbed during the swap.
f20cmx5
11
Mar 25, 2011 04:57 PM
Juan_Mitosis
May 19, 2009 08:54 PM
DarkBB4
Jul 14, 2006 05:27 AM
Freeltec
14
May 27, 2006 05:46 PM
pdorow
Jul 17, 2005 07:48 AM
