skunk2 stage 3's
Old Dec 22, 2003 | 07:04 PM
omega11855's Avatar
Default skunk2 stage 3's
yes i did a search and i couldnt find any information but what about using the stage 3's in a fully built 12.8:1 motor will they work 81.5mm bore also
with skunks valvetrain(springs and titanium retainers) and itr valves all around is it possible to daily drive these would that be enough of a built head or is there more into building a head? the bottome end is fully built with 12.8:1
Old Dec 22, 2003 | 07:44 PM
omega11855's Avatar
this is as to any valvetrain issues? and what should be done to ensure that everything is up to snuff someone please give me an idea thank you in advance Mark
Old Dec 22, 2003 | 07:58 PM
KIWI's Avatar
Default Re: skunk2 stage 3's (omega11855)
I used Skunk II Stage 3 cams in our JDM Touring car. B20 Block bored to 84.5mm 13.0 to 1 compression Endyne pistons, Eagle rods, (Alaniz) B16A Head- with all the good valve train etc. No clearance problems.
255 whp.
Split the Block in two places though!
Good Luck
Kiwi
Old Dec 23, 2003 | 01:00 AM
omega11855's Avatar
do you have the piston spec sheet by chance do you know what the valve reliefs were cut out to and what cam gear settings you used?
Old Dec 23, 2003 | 05:41 AM
Tbone's Avatar
Default Re: (omega11855)
I ran mine +1 in -1ex with 85mm IB spec super dupers and .5 oversized valves and still had v to v clearance. I run Rocket motorspots/ef-1 valvetrain btw.
Old Dec 23, 2003 | 10:00 AM
omega11855's Avatar
thanx t-bone i am also using ib spec pistons and stock sized valves so at least now i know +1 -1 is safe
Old Dec 23, 2003 | 10:19 AM
Tbone's Avatar
Well every motor is different. It will also depend on piston to deck height, gasket thickness. Valve angle.
Old Dec 23, 2003 | 10:21 AM
omega11855's Avatar
t-bone did you use them in a daily driver? could you post up the full cam specs as they show it on the sheet that comes with the cams please or anyone who has that information?
Old Dec 23, 2003 | 11:36 AM
Red D Dragon's Avatar
Ya i would check the valve clearance just to be safe with cams like that. and i really think your head would have to be port and polish and your exhaust would have to be free flowing to actually get all the cams have to offer if you have that i think that motor would rip! good luck
Old Dec 23, 2003 | 03:53 PM
omega11855's Avatar
ttt everything is ready for these cams but can they be daily driven and i still need the full spec sheet that came with them t-bone pretty pretty please w/a cherry on top
Old Dec 23, 2003 | 04:14 PM
Tbone's Avatar
I didnt get mine new.
heres a spec sheet off htec.
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
There totally dailydrivable, the non vtec lobes are small and the cams idle perfect. If your in vtec alot it will wear on your valvetrain quicker. As long as your not wailing on it all the time you should be ok. The stage 2 cam is actually the cam of choice by most.
Old Dec 24, 2003 | 08:18 PM
omega11855's Avatar
thanx i was looking for valve opening and closing specs abdc etc do you know those? and i do have 2's right now which are for sale i can get more out of my 13:1 with the 3's but yeah thanx anyone with the full spec sheet please post
Old Dec 25, 2003 | 03:08 PM
omega11855's Avatar
ttt
C2Imports
May 29, 2005 06:50 AM
IggyBcool
16
May 14, 2005 05:57 PM
EVLTEK
Jan 10, 2004 11:34 AM
GOLDBERG
May 18, 2003 10:20 PM
Mr Hammond
May 1, 2003 12:37 PM
