Sweet new piston design!
Old Dec 22, 2003 | 04:36 PM
Arsenal's Avatar
Default Sweet new piston design!
Apparently my brother was cruising at 60mph when this happened!
The Exhaust cam gear is white from extreme heat and the rockers on the exhaust cam are all off except 2.
BTW It is a 1990 DSM DOHC 2.0L N/A
Old Dec 22, 2003 | 04:41 PM
Kendall's Avatar
A prime example of why I don't buy Mitsubishi products.
Old Dec 22, 2003 | 05:34 PM
fulldragcrx's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">A prime example of why I don't buy Mitsubishi products.</TD></TR></TABLE>
you said it all brother.
not to say something like this has never happened to a honda.
Old Dec 22, 2003 | 05:37 PM
Kendall's Avatar
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">you said it all brother.
not to say something like this has never happened to a honda.</TD></TR></TABLE>
It's not about if it happens. It's about how often in happens.
Old Dec 22, 2003 | 05:46 PM
Hey , those valves are fine.
im pretty sure you could just LAP those valve back in, lol
Old Dec 22, 2003 | 06:17 PM
Arsenal's Avatar
While taking off the head the famous words came out
"This doesn't look good"
Would the crank walk that Mitsu is known for cause this?
Old Dec 22, 2003 | 06:22 PM
nope, looks like dropped valves due to over rev AKA miss shift, or some sort ov valve train malfunction. you said the cam gear was white??? Sounds like the cam was very hot due to lack of lubrication. the cam seized, pistons smacked the valves and in the process dropped a few. leaving you with what you have.
Old Dec 22, 2003 | 11:22 PM
Don Napier's Avatar
Import Alliance
Default Re: (jerseykid609)
good god!
Old Dec 22, 2003 | 11:24 PM
Silt's Avatar
Default Re: (egCivicDon)
how much can i get a set for my ls motor im building. i like that flat top design
Old Dec 26, 2003 | 04:11 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (The Raven)
holy god father!
Old Dec 27, 2003 | 08:23 PM
1700anddroping's Avatar
are those for sale hMMMMMMMMMMM.
Old Dec 28, 2003 | 01:44 AM
aeolus's Avatar
Default Re: (1700anddroping)
WOW....i bet those pistons were shot peened too!!
Old Dec 28, 2003 | 07:26 AM
boosted_zc's Avatar
Default Re: (aeolus)
well that's an easy one, the oil pump failed. Same thing happened to my 87 CRX. For some reason cruising down the street it had no problem, as soon as i got on the freeway at a constant high RPM, all of the sudden no power. I could here the engine spuddering but no power. So i cruise up the off ramp, pull off to the side and pop the hood. Nice cloud comes up from the head, i notice the timing belt is shredded. Finally get it home and take of the valve cover to find my cam melted to the head. Finally found out the oil pump was junk and wasn't suppling enough oil to the head. So it not just mitsu's, honda's go boom to.
Old Jan 3, 2004 | 04:32 PM
SyDuck's Avatar
Default Re: (boosted_zc)
whoa cooool.. do they make for 90 bmw 525i
Old Jan 3, 2004 | 06:08 PM
Arsenal's Avatar
Default Re: (SyDuck)
Available for any car, 1 test drive required!
Old Jan 3, 2004 | 07:49 PM
USDM Tsuchiya's Avatar
Default Re: (Arsenal)
WTB!
Old Jan 3, 2004 | 08:35 PM
crxluv2's Avatar
Default Re: (USDM Tsuchiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM Tsuchiya &raquo;</TD></TR><TR><TD CLASS="quote">WTB!</TD></TR></TABLE>
Those must be like 13:1!
Old Jan 3, 2004 | 08:39 PM
hotintegranights's Avatar
what compression will these piston give my integra w/ ls block/b16 head with leather seats h&R sport springs and stock 15" ls rims???
Old Jan 4, 2004 | 09:32 AM
EvilPinkEye's Avatar
Default Re: (hotintegranights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotintegranights &raquo;</TD></TR><TR><TD CLASS="quote">what compression will these piston give my integra w/ ls block/b16 head with leather seats h&R sport springs and stock 15" ls rims???</TD></TR></TABLE>
wat the, see lots of factors here
jdmekrobot
Mar 15, 2008 07:31 PM
Bisimoto
13
Jan 22, 2007 06:50 AM
EG6AAARRR!!!
Apr 22, 2005 12:54 PM
chemical
Feb 3, 2005 08:57 PM
streetrage
Oct 15, 2003 06:04 PM
