whats the color of the ignition wire under the steering wheel?
Old Dec 22, 2003 | 02:59 PM
92HPSI4WS's Avatar
Default whats the color of the ignition wire under the steering wheel?
i had an alarm in my civic that i took out and i want to install in the prelude, when i took the alarm out of the civic i didnt look at the color of the ignition wire (starter kill) does anyone know the color? thx in advance
Old Dec 22, 2003 | 03:40 PM
B18C_EJ8's Avatar
Default Re: whats the color of the ignition wire under the steering wheel? (92HPSI4WS)
You could get a meter or test light and find it... It'll be the wire that shows 12 when the key is on, while cranking and after cranking...
Old Dec 22, 2003 | 09:15 PM
92HPSI4WS's Avatar
yeah i could, i believe on the civic it was a white wire with a black stripe or a black wire with a white stripe, i cant remember not sure if it would be the same on the prelude but anyway i'll find out tomorrow, thx
Old Dec 22, 2003 | 09:43 PM
cxSHOE's Avatar
Default Re: (92HPSI4WS)
take the column cover off. and use a flashlight and find the wire that is soldered to the tab with the IGN.
Old Dec 23, 2003 | 10:49 AM
92HPSI4WS's Avatar
ok i'll look for that, thanx
Old Dec 25, 2003 | 09:55 AM
Wesyder's Avatar
ignition is black w/yellow stripe...starter is black w/white stripe...check these wires to be sure
Old Dec 25, 2003 | 10:34 AM
HNDAPWR's Avatar
Default Re: whats the color of the ignition wire under the steering wheel? (Wesyder)
I believe the last fella was right , but check to make sure, as wire colors can very from body to body and year to year.
Old Dec 25, 2003 | 11:03 AM
92HPSI4WS's Avatar
Default Re: whats the color of the ignition wire under the steering wheel? (HNDAPWR)
thanx Wesyder and HNDAPWR i'll test thoes tomorrow
mr2kqql
Jun 6, 2015 09:52 PM
ShadowBar
Jan 26, 2009 05:32 AM
22's and Man Boobs
Dec 13, 2007 04:58 PM
EK FLY
Feb 27, 2007 03:36 AM
froggysquasher
Feb 2, 2004 04:49 AM
