Need help with alarm 92-95 civic?????
Well I finally brought an 2way LCD alarm for the hatch, did all the wiring and stuff everything works except remote start, I know, I bypass the clutch already, there are few question I want to ask you guys if you know where should I look for the wire, because I am not sure if I wire the correct one or not.
First (+) Door trigger input (Dome light sensing wire)
Second (-) Door trigger input (Dome light sensing wire)
Where should I look for those and what color are those wires
and also the remote start wire.
need info ASAP thanks
Re: Need help with alarm 92-95 civic????? (mr2kqql)
ok, here is a sheet with all the wire colors for your install
wire color polarity location
12volts white + steering column
Starter black/white + steering column
Ignition black/yellow + steering column
Accessory yellow + steering column
Power Lock green/white - 2 pin plg blu-taped to blue plg behind f-box
Power Unlock green/red - same as lock
Parking Lights+ red/black + at fuse box or drivers kick panel
Door Trigger lt. green/red - driver kick panel
Trunk/Hatch Pin grn/blk 2 sil.dot - blue conn. above fusbx
Notes: On 2 doors, solid green w/ two silver dots
Tachometer blue AC 2-pin conn. near dist.
Brake Wire green/white + at brake switch
Horn Trigger blue/green - at steering column
I install about 2-4 alarm/remote starts a day, so if you have any questions feel free to ask
It is kind of hard to follow, so if you want a neater copy e-mailed to you just ask.
try http://www.bulldogsecurity.com for wiring diagrams, installation diagrams.
well, basically i install everything its an Performance teknique icbm 7071 with remote start, on the main brain it lets me switch between geneator or tach. but the thing is when I set it to tach, the remote would start the car but dies in about 2 sec, then the system will retry 3 times. but If I use the geneator mode the car would start and stay, now heres my problem, sometimes it will start and dies right away but sometimes the engine will stay on. can anyone giveme some advice on this model of alarm?
92HPSI4WS
Audio / Security / Video
12-25-2003 11:03 AM
BoostedH23a1
10-29-2002 09:35 AM
