power gains/losses from rigged up exhaust
Old Dec 22, 2003 | 02:58 PM
jerseydevil's Avatar
Default power gains/losses from rigged up exhaust
I swaped a gsr in to my del sol S. I put in the gsr manifold, downpipe and cat. The rest of the piping after the cat is the stock 1.5l non-vtec piping, including muffler. I would think that this setup would aid in lowend power, but how much am I losting up top? Below 4k the exhaust sounds deep and hollow, but not tinny. As it passes 4k it stills had the same deep tone, but muffled. I don't know if I"m just hearing the vtec come in or if the piping is just choking the engine up. It still pulls good up to 5k. I can't say about any higher than that cause I haven't gone up there yet. Waiting to get a few more mile on the rebuild before taking it any higher. Only about 700 miles on it.
Old Dec 23, 2003 | 10:34 AM
Kamin's Avatar
Default Re: power gains/losses from rigged up exhaust (jerseydevil)
it does hurt performance but there is no exact number, a full catback will be a noticable change.
Old Dec 23, 2003 | 10:45 AM
IS3Fifty's Avatar
Default Re: power gains/losses from rigged up exhaust (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">it does hurt performance but there is no exact number, a full catback will be a noticable change.</TD></TR></TABLE>
enough said. You dont want an aftermarket axel back??
Old Dec 23, 2003 | 01:46 PM
At some point I will upgrade, I just don't have the dough right now after the rebuild. Will the del sol vtec piping help? b16a piping? I'd rather stay with the quiteness of stock. I don't want to draw attention from a loud shiny exhaust.
tia
Old Dec 23, 2003 | 02:10 PM
AMeg6's Avatar
buy the apexi ws and paint it flat black all ur problems will be solved
Old Dec 24, 2003 | 08:36 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (AMeg6)
oh god, you'll see a noticable difference when you do upgrade. i kept the stock 1.5l piping on my cx and when i got the 2.25", it helped a lot at the track. good luck though.
Old Dec 24, 2003 | 09:48 AM
Shadow Templar's Avatar
Default Re: (vtecb20coupe)
i also need to upgrade my exhaust, is the apexi ws the best exhaust to use for hp gains and little fart-pipe noise? also, should a high flo cat be a better choice? i havent done anything to my motor yet, but im planning on doing a mini me on my D15B7 from a Z6 head...what would help the most?
Old Dec 24, 2003 | 05:35 PM
VTECVillain's Avatar
Default Re: (Shadow Templar)
There's a lot of debate on which is quietest, cleanest, most stock looking etc. I have an ES Oval muffler 2.5" in/out with custom piping and a GSR cat on my 92 VX with 99 B18C1 swap. It looks very stealth in the stock position with no tip and has a really deep sound, not loud buzzy and obnoxious. I have about $200 in the entire setup and you'll get no complaints from me.
Old Dec 24, 2003 | 07:46 PM
mrchris386's Avatar
Default Re: (VTECVillain)
yeah i am having the same exact problem. gsr swap with my stock dx piping...it sounds ok but it sounds like a weird quiet fart when i turn off the car. cant wait to get my apexi n1!.....startin to think about spoon n1 now though
Old Jan 6, 2004 | 01:11 PM
what kind of HP gains did u see? any at all? thanks
Charlie Moua
Jul 21, 2004 08:37 AM
blackriceman
Apr 28, 2004 10:21 AM
4thgenlude
Dec 27, 2003 09:23 AM
BlckBeautyVTEC
Nov 9, 2003 11:51 PM
Stunna BEN
Mar 18, 2002 04:30 PM
