Piston slap/knock sensor/vtec
Old Dec 22, 2003 | 02:40 PM
jerseydevil's Avatar
Default Piston slap/knock sensor/vtec
My gsr rebuild is dealig with a bit of piston slap from the forged pistons that I put in there. What is the slap doing to the knock sensor and will it prevent vtec from engaging?
Old Dec 22, 2003 | 06:45 PM
Riceburner247's Avatar
Default Re: Piston slap/knock sensor/vtec (jerseydevil)
You might want to deal with the piston slap before you start worrying about V-tec engaging.
Old Dec 23, 2003 | 08:07 AM
Dealing with the piston slap is not really an option. It involves to much more money, reboring the cylinders and getting tighter clearance pistons or cast pistons. I just don't have enough money after doing the last rebuild for that. I know there a plenty of people out there with forged pistons that deal with slap when it's cold. I just want to know if it effects vtec after it's warmed up.
Old Dec 23, 2003 | 12:41 PM
Mr. Cancer's Avatar
Default Re: (jerseydevil)
It will not affect vtec. It will affect timing. When your engine is warm, does the "slap" go away or lessen?
Old Dec 23, 2003 | 01:39 PM
yeah, once the engine is at operating temp you can't hear it, even when you get on it. Of course just because it can't be heard doesn't meant that it isn't there to some extent.
How does piston slap effect timing?
Old Dec 23, 2003 | 03:59 PM
Benny Hinn's Avatar
Piston slap doesn't, but the Knock sensor does.
Old Dec 23, 2003 | 06:18 PM
Nathan1234's Avatar
Your piston slap will be picked up by the knock sensors (when the engine is cold), and the ECU will cut timing since it thinks you are knocking. This, of course, will not happen once your car warms and the metal expands enough that the slapping goes away. You should be fine, but check the ignition timing advance at WOT to make sure it's not being retarded. If it is, you can often get an in-line resistor to "de-sensitize" the knock sensor so that it will only pick up louder real knock instead of piston slap, or "fake" knock.
Trk2112
Jun 18, 2010 08:44 AM
k-roy
Aug 16, 2004 03:53 PM
sslude
Jan 30, 2003 06:20 PM
RSvtec
Nov 15, 2002 09:23 AM
