peeps with y8 mani.. where did u place the intake air temp sensor??
Old Dec 22, 2003 | 02:26 PM
JCracer723's Avatar
Default peeps with y8 mani.. where did u place the intake air temp sensor??
where did u guys place this sensor?? since the y8 manifold dont have it .. pics would help too
tia
Old Dec 22, 2003 | 02:35 PM
MrTodd's Avatar
Default Re: peeps with y8 mani.. where did u place the intake air temp sensor?? (JCracer723)
I simply stuck it in the rubber coupling that attaches my CAI to the T/B. You could also drill a hole anywhere into the intake piping and install the sensor. It really doesn't matter where you put it - but just for a reference, the 96-00 Civic EX (Y8) has the sensor located in the airbox (where the filter is housed).
I have a pic of how I did mine, but I'd have to e-mail it to you.
Old Dec 22, 2003 | 02:43 PM
JCracer723's Avatar
Default Re: peeps with y8 mani.. where did u place the intake air temp sensor?? (MrTodd)
u got pm
Old Dec 22, 2003 | 02:51 PM
Steve91's Avatar
I extended the wires and mounted it in my AEM air filter. The AEM filter has about a 4" long rubber neck. I drilled two small holes and one larger hole in the side of the filter neck, about 1 inch from the filter. I then used some very small bolts and nuts from Home depot. Works great.
Email me if you need pics and I'll snap some tonight.
Steve
Old Dec 22, 2003 | 02:56 PM
JCracer723's Avatar
Default Re: peeps with y8 mani.. where did u place the intake air temp sensor?? (Steve91)
kool email sent
Old Dec 22, 2003 | 03:00 PM
MrTodd's Avatar
This should give you a better idea of what I'm talking about.
And another pic just to show off my mad sohc vtec skills.
Old Dec 22, 2003 | 03:04 PM
JCracer723's Avatar
oh kool ty for the pics... now wuts the other hose attached to the adapter for? .. and sorta off topic .. wut upper rad hose did u use? tia
Old Dec 22, 2003 | 03:13 PM
AgentJam's Avatar
What is that one bigger vaccume line coming off the black spacer just before the TB? It looks like it's going to that black thing against the firewall with some other red vaccum lines. My Y8 isn't hooked up like that
One more thing...does your Y8 drivers side mount sit a little towards the front of the car? Mine does...i know it is the correct mount...the one from the stock Crx engine howerver i've tried 2 mounts and they both sit a little forward.
Vince
Old Dec 22, 2003 | 04:58 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: peeps with y8 mani.. where did u place the intake air temp sensor?? (AgentJam)
i had mine in the rubber coupling before and it worked just fine. but then i switched to the 99-00 Si CAI, and used the Y8 OBD2 IAT sensor. i tested the obd2 style vs the obd0 style and the resistances were almost identical at various temperatures. the error was the same as between 2 different obd0 styles. i just spliced the new plug on since the wires have to be extended anyways. heres an old pic since i dont have any new ones on my computer as of now.
Throwdown
Dec 15, 2006 10:50 AM
EFstyle
Jul 4, 2006 12:43 AM
Vince_badaz
Oct 31, 2003 08:35 AM
JCracer723
Jul 24, 2003 09:36 PM
mooseknuckle
16
Nov 4, 2002 10:05 AM
