BOV routing
Old Dec 22, 2003 | 02:17 PM
vet_girl's Avatar
Default BOV routing
OK, so from my search I gather that the upper port of the BOV should be either run to the FPR, or the brake booster. I don't want the problem of the BOV not opening, so which should I run it to? Can someone PLEASE post a pic of where those vacuum lines are?
Old Dec 22, 2003 | 03:15 PM
flip1199's Avatar
Default Re: BOV routing (vet_girl)
just pic any vacuum source that's commin off the i/m
Old Dec 22, 2003 | 03:30 PM
vet_girl's Avatar
Default Re: BOV routing (flip1199)
how can u tell if it's a vacuum line though?
Old Dec 22, 2003 | 03:34 PM
PrecisionH23a's Avatar
Any line coming off of the intake manifold will serve as a pressure source. You can T the BOV into the FPR line. Personally, I prefer to give each component it's own individual pressure source.
Old Dec 22, 2003 | 03:49 PM
Revi's Avatar
Default Re: BOV routing (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Any line coming off of the intake manifold will serve as a pressure source. You can T the BOV into the FPR line. Personally, I prefer to give each component it's own individual pressure source.</TD></TR></TABLE>
Agreed.
GE makes a vaccum box that once connected to an existing vaccum line will have 5 or six vaccum connections available. Although this isnt exactly "independent" vaccum. It will eliminate having to T into other vacumm lines.
I personaly dont like to get vaccum from lines that are being used by other components, FPR ect. Especially if the line that is being shared by both the BOV and FPR is to disconnect. Now you have 2 problems instead of one.
Old Dec 22, 2003 | 03:54 PM
vet_girl's Avatar
Default Re: BOV routing (Revi-Ra)
OK sounds good,
I am unfamiliar with the FPR however, can someone please point me in the right direction to where I can find this vacuum line?
Old Dec 22, 2003 | 03:56 PM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vet_girl &raquo;</TD></TR><TR><TD CLASS="quote">can someone please point me in the right direction to where I can find this vacuum line?</TD></TR></TABLE>
under your hood.
Old Dec 22, 2003 | 04:25 PM
Revi's Avatar
Its connected to your Fuel Rail, the fuel rail sits on your intake manifold.
http://www.slhondaparts.com/im...3.jpg
Its #8 in this diagram
Old Dec 22, 2003 | 06:21 PM
vet_girl's Avatar
under the hood huh, yea, good call, i was looking under the car for the fpr. Anyways, i see it now, thanks guys
v.i.gsr
Jul 13, 2011 04:09 PM
Dan_Roc
Feb 6, 2007 12:55 PM
bipedbear
Oct 19, 2004 01:18 PM
@irborne
Apr 4, 2003 02:06 PM
greyzone
Jun 28, 2001 12:53 PM
