integra 93, CEL code 43 - fuel supply system ???
Old Dec 22, 2003 | 11:07 AM
BassBoy19's Avatar
Default integra 93, CEL code 43 - fuel supply system ???
We got a 93 integra here that is turbo with an SDS aditional injector controler, recently we got a 43 CEL that says the fuel supply is defective and the A/F meter is now saying lean all the time...what can it be, we are running the stock pump at 14 psi...2 weeks ago even with the stock pump there was no trouble and we were able to get a rich mixture at WOT... what can be our problem thanks...
Old Dec 22, 2003 | 12:22 PM
..::91TEG-G2::..'s Avatar
Default Re: integra 93, CEL code 43 - fuel supply system ??? (BassBoy19)
u alwasy get a bigger fuel pump when ur running boost ur engine needs that extra fuel even if u dont think it does
Old Dec 22, 2003 | 12:27 PM
BassBoy19's Avatar
we got anholley fuel pump but not installed yet, but the thing is that the negine runs witout problems during like 2000 km an after the trouble started, maybe the fuel pump was good for a short amount if time but now got tired up ( stock pump 270 000 km )
Old Dec 22, 2003 | 12:36 PM
Default Re: (BassBoy19)
did u check the filter on the stock pump?
Old Dec 22, 2003 | 02:21 PM
thelate1's Avatar
i had the same code, turned out to be my ground wire at my thermostat was loose!
just a thought.
shawn
Old Dec 22, 2003 | 08:38 PM
BassBoy19's Avatar
we ll try a new O2 sensor by tomo to see if its that...
jaredvabeach
15
Jun 21, 2008 05:38 PM
Rikter
Sep 11, 2006 02:21 PM
triple_s1x
Dec 10, 2004 07:47 PM
civicdragger818
Dec 4, 2002 09:25 AM
