flywheel
Old Sep 23, 2001 | 12:54 PM
Kamin's Avatar
Default flywheel
Is it worth it to get an aluminum flywheel? let me tell you my plans, 15+lb of boost on a b16a2. so would an aluminum flywheel hold up? also what kind of clutch should i get. i would like to still retain smooth ride but have good race preformance.
Old Sep 23, 2001 | 10:11 PM
Kamin's Avatar
Default Re: flywheel (KAMiN)
come on guys
100+ views no help!
Old Sep 23, 2001 | 10:30 PM
Slain's Avatar
yeah i'd say its worth if if u are planning on boosting ur car. it allows the engine to rev faster due to the rotational mass ( of having a lighter flywheel) clutchmasters make both flywheels and clutches so check them out. if you are gonna be running 15lbs better get a tough clutch act, exedy, clutchmasters
[Modified by Slain, 1:31 AM 9/24/2001]
Old Sep 23, 2001 | 10:36 PM
Kamin's Avatar
Default Re: flywheel (Slain)
is an aluminum flywheel strong enough for that much boost tho?
[Modified by KAMiN, 7:37 AM 9/24/2001]
Old Sep 23, 2001 | 10:47 PM
Slain's Avatar
i'd say yeah it should be enough unless you are gonna be running more later on down the line
Old Sep 23, 2001 | 11:05 PM
Kamin's Avatar
thanks for the info , if i go above 20 in the future what should i look at for a flywheel. thanks again
Old Sep 24, 2001 | 01:24 AM
martini's Avatar
What does your flywheel have to do with how much boost you're running?
Old Sep 24, 2001 | 11:13 AM
Kamin's Avatar
Default Re: flywheel (martini)
nothing directly but if the engine is producing 300lb of torque and your using an aluminum flywheel im curious as to if it would hold up.
[Modified by KAMiN, 7:15 AM 9/25/2001]
drintegra
May 14, 2006 04:35 PM
Rocks
Aug 23, 2004 12:27 PM
T3T495GSR
Jun 1, 2003 05:43 AM
twitchm80
Oct 4, 2002 09:17 AM
SPOON_BeIgHtEeNsEe
Aug 29, 2001 12:54 PM
