Fork and Control Arm bolt
Old Dec 22, 2003 | 05:48 AM
James's Avatar
Default Fork and Control Arm bolt
Hi -
How do you remove the bolt that holds lower control arm to fork? It seems to rusted froze inside the control arm bushing. I tried to knock it out with a hammer but with no luck. Also, do you need to remove the fork/control arm connection to remove drive shaft?
Thanks.
Jim
Old Dec 22, 2003 | 06:01 AM
boonacka's Avatar
Default Re: Fork and Control Arm bolt (James)
yes the fork has to be removed to take out the drive shaft. spray it good with some lube and hit it a few times with a hammer then let it soak in. if you have a pretty strong impact gun (500 ft/lbs) hit it good going back and forth (fwd/rev) until it comes out easily. if you dont have an impact gun, use a long breaker bar/pipe. chances are that if you dont have the impact sockets (black) you'll break the chrome sockets or shear the bolt itself. good luck.
Old Dec 23, 2003 | 08:13 PM
corymedlin's Avatar
Default Re: Fork and Control Arm bolt (boonacka)
got the same problem here. Broke off the bolt head, other end broke off too after soaking for 2 days in PBlaster, sledge hammer w/punch does nothing: stuck little sucker. Looks like I will have to cut through the lower ctl arm bushing and cut it out that way.
myownreality
Feb 9, 2013 10:43 PM
allums34
Apr 13, 2011 09:55 AM
corkss
10
Mar 19, 2009 07:00 PM
ILcrxsi1
Jul 22, 2006 10:54 AM
kyden
Suspension & Brakes
Jan 25, 2006 10:56 PM
