Cat-back recommendation
Old Dec 22, 2003 | 05:47 AM
bfitz's Avatar
Default Cat-back recommendation
I looking for recommendations for a cat-back system. I've searched the archives and didn't come up with much on cat-back-only results.
I'm going to autocross my ITR car in stock class, so it won't have any other engine mods. The top priority is mid-range power, then weight. I don't expect much, but 3-4 hp, with no losses elsewhere in the rpm-range, would be worth it to me.
Are there any gains to be had over the stock system? Should I just replace the muffler?
Also, I'd appreciate any links to dyno results comparing stock to cat-back.
Thanks,
Brian Fitzpatrick
'01 PY ITR
Old Dec 22, 2003 | 06:10 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Cat-back recommendation (bfitz)
https://honda-tech.com/zerothread?id=139319
https://honda-tech.com/zerothread?id=100306
https://honda-tech.com/zerothread?id=110314
https://honda-tech.com/zerothread?id=107971
https://honda-tech.com/zerothread?id=96621
You need some practice with the search function then. 200 results for "cat-back", 203 results for "cat-back exhaust". Make sure you select the "archived" button on the right.
There are gains to be had over the stock system, but usually not with just an axle-back (muffler). If you combined that with larger diameter piping from the cat, that'd be another story. It also depends on what you're looking for, is it max power, sound, driveability, etc. Buddy Club Spec II would probably give you some of the highest power yields, but it's also one of the loudest ones out there.
Old Dec 22, 2003 | 08:18 AM
92TypeR's Avatar
FSAE
Default Re: Cat-back recommendation (sscguy)
I got 15whp/11tq from my setup:
https://honda-tech.com/zerothread?id=659143
Talk to Mike @ IPSracing.com, probably wont have any in until late Jan.
Old Dec 22, 2003 | 09:30 AM
bfitz's Avatar
Default Re: Cat-back recommendation (92TypeR)
I did find a bunch of stuff in the archives, but I didn't find much useful info regarding just a cat-back. It seems like a header and cat is worth quite a bit, but I can't touch those.
So, assuming stock header and cat, are there gains to be made with a cat-back system without hurting mid-range torque?
There are things I'd like in an exhaust, and the stock one fits those criteria well, but I'll give up some things for a few hp.
Brian
Old Dec 22, 2003 | 09:44 AM
Champ R's Avatar
A cat-back alone isnt going to do much but add sound, you need to eliminate the first big bottlenecks that are the header and stock catalytic.
Old Dec 22, 2003 | 09:58 AM
Nice_Dc2r's Avatar
RsR Ex Mag Gt2, Jdm Itr cat, Jdm DC 4-1 header
http://www.rs-r.com/exmag_gt2.htm
Awesome midrange and top end gains
Sounds really good too.
Old Dec 22, 2003 | 10:05 AM
jaa1311's Avatar
w/ my jdm itr 4-1 to 2.5" smsp cat to t1r catback i noticed nice gains on the butt dyno , but just doing a catback isnt going to net you much of a gain
Old Dec 22, 2003 | 10:54 AM
HYREV2NR's Avatar
Apex N1. I noticed good gains from idle up as soon as I put it on.
Old Dec 22, 2003 | 02:41 PM
nsxjr2's Avatar
JIC
zerovandez
Apr 1, 2017 08:12 PM
A's 94 GSR
Oct 17, 2012 04:12 PM
adalsteinsson
Northwest
25
Aug 3, 2011 11:03 AM
xkagax
Mar 15, 2008 06:01 PM
B18Redline
Dec 24, 2004 09:29 PM
