ITR M/C and Brake booster in EK issues.
Old Dec 21, 2003 | 08:29 PM
soundbomber's Avatar
Default ITR M/C and Brake booster in EK issues.
Well, my brake swap was just completed yesterday and along with that went the 1" itr master cylinder and the corresponding brake booster. Everything seemed fine and the lines were bled pretty well. We didn't notice we had a problem until the car was taken out for a drive and returned. It seems that there is a vacuum leak in the booster between the master cylinder and the booster. This is causing a loud hissing noise whenever the car is on. Also, the brakes aren't very compliant but do work. There isn't a problem with a surging idle or anything. Now my question is, is the problem originating from the booster itself because it's not holding vacuum or is there a problem with the seal between the master cylinder and the booster? Any suggestions would be appreciated. TIA
ng's Avatar
ng
Not sure, but I think the seal would be easiest to test. If you can get a peak at it with the car on you should be able to find the leak.
Old Dec 21, 2003 | 08:31 PM
Default Re: (ng)
Oops, sorry I forgot to mention that we are pretty sure the leak is at the bottom of the m/c and booster mounting area.
Old Dec 22, 2003 | 12:07 PM
Default Re: (soundbomber)
anyone? anyone?
Old Dec 22, 2003 | 12:50 PM
ek four's Avatar
sup soundbomber. i hate it when we put in all the work to have **** fail. good luck on getting the part and let us know.
Old Dec 22, 2003 | 06:52 PM
Default Re: (ek four)
word "eck fore" ******* i got my alignment done today, and the rear is off. I suspect bent rear trailing arms. Anyways, we're gonna try and use the drum trailing arms. And the booster is BANK brand new.
Old Dec 22, 2003 | 08:03 PM
Petah's Avatar
Try applying the brakes with the car no moving....if the pedal continues to move downwards slowly after you have hit the "stop" point, that means your booster is not holding pressure and is leaking.
Old Dec 22, 2003 | 10:24 PM
Default Re: (Petah)
nah, i don't have that kind of problem. The brake pedal stops at that stop point
Old Dec 23, 2003 | 06:21 PM
E-Rok's Avatar
EPIC TUNING
its a leak around the seal where the MC bolts to it. i have the same problem. the booser is probably slightly bent around that area. try flattening it and putting some liquid gasket on it.
Old Dec 23, 2003 | 06:58 PM
Default Re: (rewsnaeht)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">its a leak around the seal where the MC bolts to it. i have the same problem. the booser is probably slightly bent around that area. try flattening it and putting some liquid gasket on it.</TD></TR></TABLE>
HELL YEAH! Cheers. Thanks man. I knew i cruise this board all day for a reason. Any suggestions as to what to seal it with? silicone or something?
bigrob119
Oct 18, 2009 04:02 PM
Specail Ed
Mar 31, 2008 08:25 AM
CRITTERMATT
Dec 4, 2007 09:37 AM
dxhatch92
Jan 16, 2007 08:13 PM
4play4dr
Nov 26, 2006 08:35 PM
