y1 lsd fit in ys1?
Old Dec 21, 2003 | 05:24 PM
jDMJeRk's Avatar
Default y1 lsd fit in ys1?
I have a 91 LS; I want to know if i can put the LSD outta my y1 into my stock ys1 tranny...they are both cable
Old Dec 22, 2003 | 12:09 AM
jDMJeRk's Avatar
Default Re: y1 lsd fit in ys1? (jdmjerk)
Old Dec 22, 2003 | 08:59 AM
Jasper_db1's Avatar
No, it won't.
Old Dec 22, 2003 | 11:10 AM
jDMJeRk's Avatar
Default Re: y1 lsd fit in ys1? (Jasper_db1)
does anyone else now....it seems to me if you can interchange the gears from a ys1 to a y1 and vise verse; why couldnt ou change the lsd?
Old Dec 22, 2003 | 11:20 AM
Gabe_'s Avatar
No, you can not. I forgot exactly why, but I am pretty sure that you can not.
There are a few major differences (asides from gearing) between the ys1, and the other b-series cable trannies.
Old Dec 22, 2003 | 11:29 AM
jDMJeRk's Avatar
err ok...
Old Dec 22, 2003 | 11:33 AM
Gabe_'s Avatar
Default Re: (jdmjerk)
Try posting on g2ic.com, I am sure you can get a more defineate answer there. I am sorry I am not of more help. I just remember reading/hearing it somewhere...
Old Dec 22, 2003 | 12:54 PM
Gabe_'s Avatar
Default Re: (Gabe_)
I found out why... after some quick research. The Y1 LSD is welded to the Y1 final drive, so it would defeat the whole pupose of having a YS1.
Old Dec 22, 2003 | 10:54 PM
Newman's Avatar
New User
Different diff & shaft sizes. But you can modify & shim an ITR LSD diff into a YS1, but it's still a good amount of work, but it's been done.
Old Dec 23, 2003 | 12:30 AM
jDMJeRk's Avatar
its possibly; i posted it on g2ic.com here is the post
"the gears are not interchangable. but you can put the lsd diff from a y1 into a ys1 as long as you change the counter shaft to a 4:26 final. being that the 89-91 y1 trans only came with a 4:26 and the ys1 came with a 4:40."
Old Dec 23, 2003 | 04:24 AM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">its possibly; i posted it on g2ic.com here is the post
"the gears are not interchangable. but you can put the lsd diff from a y1 into a ys1 as long as you change the counter shaft to a 4:26 final. being that the 89-91 y1 trans only came with a 4:26 and the ys1 came with a 4:40."</TD></TR></TABLE>
Which is what I said, although I may have been wrong about it being welded... It would be pointless. Your YS1 would no longer have the hot gearing of the YS1... which would make having a YS1 pointless, IMO.
Modified by Gabe_ at 3:06 PM 12/23/2003
Old Dec 23, 2003 | 10:48 AM
acy76's Avatar
I am not sure which YS-1 you have, but as far as I know the non-GSR model has got the 4.266:1 final drive, same as the 90-91 integra transmission. Maybe that's what you were referring to.
Old Dec 23, 2003 | 11:06 AM
Gabe_'s Avatar
Default Re: (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure which YS-1 you have, but as far as I know the non-GSR model has got the 4.266:1 final drive, same as the 90-91 integra transmission. Maybe that's what you were referring to.</TD></TR></TABLE>
Good call...
Old Dec 23, 2003 | 02:43 PM
Jasper_db1's Avatar
Default Re: y1 lsd fit in ys1? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">But you can modify & shim an ITR LSD diff into a YS1, but it's still a good amount of work, but it's been done.</TD></TR></TABLE>
Yup, I have an ITR LSD in my YS1
Old Dec 23, 2003 | 04:37 PM
ljoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, I have an ITR LSD in my YS1</TD></TR></TABLE>
what exactly did you have to do to make that fit?
Old Dec 23, 2003 | 04:41 PM
Jasper_db1's Avatar
Default Re: y1 lsd fit in ys1? (ljoe)
A freind of mine builds transmissions. I purchased the LSD and a DC2 4.40 ring gear and sent it to him.
Please note that if you intend to use an LSD meant for the DC2 or ITR, you need to use a DC2 or ITR ring gear. The YS1 and 99+ Civic Si ones are too small.
Old Dec 23, 2003 | 07:31 PM
ljoe's Avatar
alright, thanks a lot
civic2slo
Mar 9, 2009 07:48 AM
92integraVTECgsr
Nov 29, 2005 02:06 PM
Mattamotor
Jun 8, 2004 06:59 PM
Jared
10
Feb 28, 2003 06:24 PM
CivicSiR7
11
Feb 18, 2002 10:10 AM
