rim & tire size ????
Old Dec 21, 2003 | 03:57 PM
RUBZERK's Avatar
Default rim & tire size ????
Im looking to get a set of these rims in 17'' or 18" not sure yet.
what tire sizes would you use ???
91 4 door accord
Old Dec 21, 2003 | 05:08 PM
FatJoe's Avatar
Default Re: rim & tire size ???? (RUBZERK)
if you got 18's, you would have to use something like 215/40 and below. i think 225 would rub. hell 215 would prolly rub sometimes too
Old Dec 21, 2003 | 06:21 PM
Hondaaccordvtec's Avatar
Default Re: rim & tire size ???? (H22Accord90DX)
Well, for my 17's, I use a 215/40.
Old Dec 21, 2003 | 11:46 PM
Starrman85's Avatar
Default Re: rim & tire size ???? (Hondaaccordvtec)
for my 17's i use 215/45.
Old Dec 22, 2003 | 07:04 AM
RUBZERK's Avatar
Default Re: rim & tire size ???? (STARRMAN85)
WHAT ARE THE REASON FOR THESE SIZES?
Old Dec 22, 2003 | 08:08 AM
.bagged's Avatar
I think in order to keep your speedo in check you need to use, 215/40 for the 17's, it gives you enough rubber on the road, and is the correct plus size. check rubbage though. a friend of mine that drives a 93 had to go to a 205 cause the 215's rubbed on her 3" drop...
Old Dec 22, 2003 | 11:16 AM
Starrman85's Avatar
Default Re: rim & tire size ???? (bagged93accord)
the different numbers stand for different things. take a 215/45/17 tire...
the 215 is the width of the tire...in milimeters i believe...so it would be a 21.5cm wide tire. the 45 is pretty much size of the sidewall, but i'm not sure how its measured, but the higher the number, the bigger the sidewall, and the 17...well, thats for the size rim your putting the tire on.
hope this helps.
Old Dec 22, 2003 | 12:10 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">
hope this helps.</TD></TR></TABLE>
the 45 is 45% of the width of the tire. so the sidewall for a 215/45/17 would be 45%of 215
Old Dec 22, 2003 | 06:54 PM
Riceburner247's Avatar
205/40/R17
205 - width of the tire
40 - height of the sidewall
R - Radial tire
17 - size of rim tire will fit
maybe you people should look in on the civic forum every once in a while............ (j/k)
Old Dec 22, 2003 | 07:21 PM
2+2=5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">for my 17's i use 215/45.</TD></TR></TABLE>
same for me....no need to get rubber band tires and get your rims bent.
that's how i see it, plus i got abunch of bumpy road and parking lot here to hike over
Old Dec 22, 2003 | 09:09 PM
Starrman85's Avatar
Default Re: rim & tire size ???? (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">
that's how i see it, plus i got abunch of bumpy road and parking lot here to hike over</TD></TR></TABLE>
yea, thats way i see it. more cushion for the pushin...sort of
Old Dec 22, 2003 | 10:06 PM
RUBZERK's Avatar
CAN YOU POST YOUR RIM PICS?
Old Dec 22, 2003 | 10:28 PM
Nick H's Avatar
New User
225/45/17 will fit on 17x7 or 17x7.5...i think 235/45/17 is where it starts to rub without some spacers...
Old Dec 22, 2003 | 10:41 PM
Starrman85's Avatar
Default Re: rim & tire size ???? (Nick H)
17" rims, lowered on h&r sport springs.
mikeaitken
Sep 11, 2007 01:41 PM
HuskerHybrid
Aug 26, 2005 06:58 PM
vaggabon
Apr 25, 2004 10:07 PM
1NasteeEp
Apr 10, 2004 08:13 AM
TrueZen
Apr 24, 2003 05:38 PM
